Datasheet LT6402-20 (Analog Devices) - 2
Description300MHz Low Distortion, Low Noise Differential Amplifier/ADC Driver (AV = 20dB)
Pages / Page16 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order …
File Format / SizePDF / 338 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order Options. The. DC ELECTRICAL CHARACTERISTICS
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) Order Options The DC ELECTRICAL CHARACTERISTICS
LT6402-20
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
TOP VIEW Total Supply Voltage (VCCA/VCCB/VCCC to VEEA/VEEB/VEEC) ...5.5V +INA +INB –INA –INB Input Current (+INA, –INA, +INB, –INB, 16 15 14 13 V 1 12 V V CCC EEC OCM, ENABLE) ..±10mA V 2 11 OCM ENABLE Output Current (Continuous) 17 VCCA 3 10 VCCB +OUT, –OUT ...±100mA VEEA 4 9 VEEB +OUTFILTERED, –OUTFILTERED ..±30mA 5 6 7 8 Output Short Circuit Duration (Note 2) .. Indefi nite +OUT –OUT Operating Temperature Range (Note 3) ... –40°C to 85°C Specifi ed Temperature Range (Note 4) .. –40°C to 85°C +OUTFILTERED –OUTFILTERED Storage Temperature Range ... –65°C to 125°C UD PACKAGE Junction Temperature ... 125°C 16-LEAD (3mm × 3mm) PLASTIC QFN Lead Temperature Range (Soldering 10 sec) .. 300°C TJMAX = 125°C, θJA = 68°C/W, θJC = 4.2°C/W EXPOSED PAD IS VEE (PIN 17) MUST BE SOLDERED TO THE PCB ORDER PART NUMBER UD PART MARKING* LT6402CUD-20 LCBC LT6402IUD-20 LCBC
Order Options
Tape and Reel: Add #TR Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. *The temperature grade is identifi ed by a label on the shipping container.
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCCA = VCCB = VCCC = 5V, VEEA = VEEB = VEEC = 0V,
E
N
A
B
L
E = 0.8V, +INA shorted to +INB (+IN), –INA shorted to –INB (–IN), VOCM = 2.2V, Input common mode voltage = 2.2V, no RLOAD unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Input/Output Characteristics (+INA, +INB, –INA, –INB, +OUT, –OUT, +OUTFILTERED, –OUTFILTERED)
GDIFF Gain Differential (+OUT, –OUT), VIN = ±160mV ● 18.9 20 20.9 dB Differential VSWINGMIN Single-Ended +OUT, –OUT, +OUTFILTERED, 0.25 0.35 V –OUTFILTERED, VIN = ±600mV Differential ● 0.5 V VSWINGMAX Single-Ended +OUT, –OUT, +OUTFILTERED, 3.4 3.6 V –OUTFILTERED, VIN = ±600mV Differential ● 3.3 V VSWINGDIFF Output Voltage Swing Differential (+OUT, –OUT), VIN = ±600mV 6.1 7 VP-P Differential ● 5.6 VP-P IOUT Output Current Drive ● ±30 ±35 mA VOS Input Offset Voltage –6.5 1 6.5 mV ● –10 10 mV TCVOS Input Offset Voltage Drift TMIN to TMAX ● 2.5 µV/°C 640220fa 2
