Datasheet LT6402-20 (Analog Devices) - 3
Description300MHz Low Distortion, Low Noise Differential Amplifier/ADC Driver (AV = 20dB)
Pages / Page16 / 3 — The. DC ELECTRICAL CHARACTERISTICS. denotes the specifi cations which …
File Format / SizePDF / 338 Kb
The. DC ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating
The DC ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating
LT6402-20
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCCA = VCCB = VCCC = 5V, VEEA = VEEB = VEEC = 0V,
E
N
A
B
L
E = 0.8V, +INA shorted to +INB (+IN), –INA shorted to –INB (–IN), VOCM = 2.2V, Input common mode voltage = 2.2V, no RLOAD unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
IVRMIN Input Voltage Range, MIN Single-Ended ● 0.9 V IVRMAX Input Voltage Range, MAX Single-Ended ● 3.9 V RINDIFF Input Resistance ● 77 100 122 Ω CINDIFF Input Capacitance 1 pF CMRR Common Mode Rejection Ratio Input Common Mode 0.9V to 3.9V ● 45 70 dB ROUTDIFF Output Resistance 0.3 Ω COUTDIFF Output Capacitance 0.8 pF
Common Mode Voltage Control (VOCM Pin)
GCM Common Mode Gain Differential (+OUT, –OUT), VOCM = 1.2V to 3.6V 0.9 1 1.1 V/V Differential (+OUT, –OUT), VOCM = 1.4V to 3.4V ● 0.9 1.1 V/V VOCMMIN Output Common Mode Voltage 1.2 V Adjustment Range, MIN ● 1.4 V VOCMMAX Output Common Mode Voltage Single-Ended 3.6 V Adjustment Range, MAX ● 3.4 V VOSCM Output Common Mode Offset Measured from VOCM to Average of +OUT and –OUT –30 4 30 mV Voltage IBIASCM VOCM Input Bias Current ● 5 15 µA RINCM VOCM Input Resistance ● 0.8 3 MΩ CINCM VOCM Input Capacitance 1 pF ⎯
E
N
A
B
L
E Pin
VIL ⎯E⎯N⎯A⎯B⎯L⎯E Input Low Voltage ● 0.8 V VIH ⎯E⎯N⎯A⎯B⎯L⎯E Input High Voltage ● 2 V IIL ⎯E⎯N⎯A⎯B⎯L⎯E Input Low Current ⎯E⎯N⎯A⎯B⎯L⎯E = 0.8V ● 0.5 µA IIH ⎯E⎯N⎯A⎯B⎯L⎯E Input High Current ⎯E⎯N⎯A⎯B⎯L⎯E = 2V ● 1 3 µA
Power Supply
VS Operating Range ● 4 5 5.5 V IS Supply Current ⎯E⎯N⎯A⎯B⎯L⎯E = 0.8V ● 24 30 37 mA ISDISABLED Supply Current (Disabled) ⎯E⎯N⎯A⎯B⎯L⎯E = 2V ● 250 500 µA PSRR Power Supply Rejection Ratio 4V to 5.5V ● 55 90 dB 640220fa 3
