Datasheet LT6600-10 (Analog Devices) - 2
DescriptionVery Low Noise, Differential Amplifier and 10MHz Lowpass Filter
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 204 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT6600-10
Total Supply Voltage ...11V Junction Temperature ... 150°C Input Current (Note 8) ..±10mA Storage Temperature Range ... –65°C to 150°C Operating Temperature Range (Note 6).. –40°C to 85°C Lead Temperature (Soldering, 10 sec) .. 300°C Specifi ed Temperature Range (Note 7) .. –40°C to 85°C
PIN CONFIGURATION
TOP VIEW TOP VIEW IN– 1 12 IN+ NC 2 11 NC IN– 1 8 IN+ V 3 10 V OCM 13 MID V 2 7 V OCM MID V+ 4 9 V– V+ 3 6 V– NC 5 8 V– OUT+ 4 5 OUT– OUT+ 6 7 OUT– DF PACKAGE S8 PACKAGE 12-LEAD (4mm s 4mm) PLASTIC DFN 8-LEAD PLASTIC SO T T JMAX = 150°C, θJA = 43°C/W, θJC = 4°C/W JMAX = 150°C, θJA = 100°C/W EXPOSED PAD (PIN 13) IS V–, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6600CS8-10#PBF LT6600CS8-10#TRPBF 660010 8-Lead Plastic SO 0°C to 70°C LT6600IS8-10#PBF LT6600IS8-10#TRPBF 600I10 8-Lead Plastic SO –40°C to 85°C LT6600CDF-10#PBF LT6600CDF-10#TRPBF 60010 12-Lead (4mm × 4mm) Plastic DFN 0°C to 70°C LT6600IDF-10#PBF LT6600IDF-10#TRPBF 60010 12-Lead (4mm × 4mm) Plastic DFN –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT6600CS8-10 LT6600CS8#TR 660010 8-Lead Plastic SO 0°C to 70°C LT6600IS8-10 LT6600IS8-10#TR 600I10 8-Lead Plastic SO –40°C to 85°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. Consult LTC Marketing for information on non-standard lead based fi nish parts. The temperature grade is identifi ed by a label on the shipping container for the DFN Package. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 66001fe 2
