Datasheet LT6600-10 (Analog Devices) - 3
DescriptionVery Low Noise, Differential Amplifier and 10MHz Lowpass Filter
Pages / Page16 / 3 — The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply …
File Format / SizePDF / 204 Kb
The. ELECTRICAL CHARACTERISTICS. denotes the specifi cations which apply over the full operating temperature
The ELECTRICAL CHARACTERISTICS denotes the specifi cations which apply over the full operating temperature
LT6600-10
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. Unless otherwise specifi ed VS = 5V (V+ = 5V, V– = 0V), RIN = 402
Ω
, and RLOAD = 1k. PARAMETER CONDITIONS MIN TYP MAX UNITS
Filter Gain, VS = 3V VIN = 2VP-P , fIN = DC to 260kHz –0.4 0 0.5 dB VIN = 2VP-P , fIN = 1MHz (Gain Relative to 260kHz) l –0.1 0 0.1 dB VIN = 2VP-P , fIN = 5MHz (Gain Relative to 260kHz) l –0.4 –0.1 0.3 dB VIN = 2VP-P , fIN = 8MHz (Gain Relative to 260kHz) l –0.3 0.1 1 dB VIN = 2VP-P , fIN = 10MHz (Gain Relative to 260kHz) l –0.2 0.3 1.7 dB VIN = 2VP-P , fIN = 30MHz (Gain Relative to 260kHz) l –28 –25 dB VIN = 2VP-P , fIN = 50MHz (Gain Relative to 260kHz) l –44 dB Filter Gain, VS = 5V VIN = 2VP-P , fIN = DC to 260kHz –0.5 0 0.5 dB VIN = 2VP-P , fIN = 1MHz (Gain Relative to 260kHz) l –0.1 0 0.1 dB VIN = 2VP-P , fIN = 5MHz (Gain Relative to 260kHz) l –0.4 –0.1 0.3 dB VIN = 2VP-P , fIN = 8MHz (Gain Relative to 260kHz) l –0.4 0.1 0.9 dB VIN = 2VP-P , fIN = 10MHz (Gain Relative to 260kHz) l –0.3 0.2 1.4 dB VIN = 2VP-P , fIN = 30MHz (Gain Relative to 260kHz) l –28 –25 dB VIN = 2VP-P , fIN = 50MHz (Gain Relative to 260kHz) l –44 dB Filter Gain, VS = ±5V VIN = 2VP-P , fIN = DC to 260kHz –0.6 –0.1 0.4 dB Filter Gain, RIN = 100Ω, VS = 3V, 5V, ±5V VIN = 0.5VP-P , fIN = DC to 260kHz 11.4 12 12.6 dB Filter Gain Temperature Coeffi cient (Note 2) fIN = 260kHz, VIN = 2VP-P 780 ppm/C Noise Noise BW = 10kHz to 10MHz, RIN = 402Ω 56 μVRMS Distortion (Note 4) 1MHz, 2VP-P , RL = 800Ω 2nd Harmonic 88 dBc 3rd Harmonic 97 dBc 5MHz, 2VP-P , RL = 800Ω 2nd Harmonic 74 dBc 3rd Harmonic 77 dBc Differential Output Swing Measured Between Pins 4 and 5 VS = 5V l 3.85 5.0 VP-P DIFF Pin 7 Shorted to Pin 2 VS = 3V l 3.85 4.9 VP-P DIFF Input Bias Current Average of Pin 1 and Pin 8 l –85 –40 μA Input Referred Differential Offset RIN = 402Ω VS = 3V l 5 20 mV VS = 5V l 10 30 mV VS = ±5V l 8 35 mV RIN = 100Ω VS = 3V l 5 13 mV VS = 5V l 5 22 mV VS = ±5V l 5 30 mV Differential Offset Drift 10 μV/°C 66001fe 3
