Datasheet LT6600-10 (Analog Devices) - 6
Description | Very Low Noise, Differential Amplifier and 10MHz Lowpass Filter |
Pages / Page | 16 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Distortion vs Frequency. Distortion … |
File Format / Size | PDF / 204 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Distortion vs Frequency. Distortion vs Signal Level. IN = 2VP-P, VS = ±5V, RL = 800
LT6600-10
TYPICAL PERFORMANCE CHARACTERISTICS Distortion vs Frequency Distortion vs Signal Level Distortion vs Signal Level V V IN = 2VP-P, VS = ±5V, RL = 800
Ω
S = 3V, RL = 800
Ω
at Each VS = ±5V, RL = 800
Ω
at Each at Each Output, T Output, T A = 25°C A = 25°C Output, TA = 25°C
–40 –40 –40 DIFFERENTIAL INPUT, 2ND HARMONIC, 2ND HARMONIC, 2ND HARMONIC 5MHz INPUT 5MHz INPUT –50 DIFFERENTIAL INPUT, –50 3RD HARMONIC, –50 3RD HARMONIC, 3RD HARMONIC 5MHz INPUT 5MHz INPUT SINGLE-ENDED INPUT, 2ND HARMONIC, 2ND HARMONIC, –60 –60 2ND HARMONIC –60 1MHz INPUT 1MHz INPUT SINGLE-ENDED INPUT, 3RD HARMONIC, 3RD HARMONIC, 1MHZ INPUT 3RD HARMONIC 1MHZ INPUT –70 –70 –70 –80 DISTORTION (dB) –80 DISTORTION (dB) –80 DISTORTION (dB) –90 –90 –90 –100 –100 –100 –110 0.1 1 10 0 1 2 3 4 5 0 1 2 3 4 5 FREQUENCY (MHz) INPUT LEVEL (VP-P) INPUT LEVEL (VP-P) 6600 G08 6600 G09 6600 G10
Distortion vs Input Common Mode Distortion vs Input Common Mode Level, 2V Power Supply Current P-P, 1MHz Input, 1x Gain, Level, 0.5VP-P, 1MHz Input, 4x Gain, R vs Power Supply Voltage L = 800
Ω
at Each Output, TA = 25°C RL = 800
Ω
–40 –40 40 2ND HARMONIC, 2ND HARMONIC, V V S = 3V S = 3V 38 –50 3RD HARMONIC, –50 3RD HARMONIC, TA = 85°C V V S = 3V S = 3V 2ND HARMONIC, 2ND HARMONIC, 36 –60 V V S = 5V –60 S = 5V 3RD HARMONIC, 3RD HARMONIC, 34 TA = 25°C V V S = 5V S = 5V –70 –70 32 30 –80 –80 TA = –40°C 28 DISTORTION COMPONENT (dB) –90 DISTORTION COMPONENT (dB) –90 POWER SUPPLY CURRENT (mA) 26 –100 –100 24 –3 –2 –1 0 1 2 3 –3 –2 –1 0 1 2 3 2 3 4 5 6 7 8 9 10 INPUT COMMON MODE VOLTAGE INPUT COMMON MODE VOLTAGE TOTAL SUPPLY VOLTAGE (V) RELATIVE TO V RELATIVE TO V MID (V) MID (V) 6600 G11 6600 G12 6600 G13
Transient Response, Distortion vs Output Common Mode, Differential Gain = 1 2VP-P 1MHz Input, 1x Gain, TA = 25°C
–40 –50 V + OUT 50mV/DIV –60 2ND HARMONIC, VS = 3V 3RD HARMONIC, VS = 3V DIFFERENTIAL 2ND HARMONIC, VS = 5V INPUT –70 3RD HARMONIC, VS = 5V 200mV/DIV 2ND HARMONIC, VS = ±5V –80 3RD HARMONIC, VS = ±5V 100ns/DIV 6600 G14 DISTORTION COMPONENT (dB) –90 –100 –1 –0.5 0 0.5 1 1.5 2 OUTPUT COMMON MODE VOLTAGE (V) 6600 G15 66001fe 6
