AD8367Parameter ConditionsMinTypMaxUnit f = 140 MHz Gain Maximum gain +43.5 dB Minimum gain −3.6 dB Gain Scaling Factor 19.7 mV/dB Gain Intercept −5.3 dB Noise Figure Maximum gain 7.4 dB Output IP3 f1 = 140 MHz, f2 = 141 MHz, VGAIN = 0.5 V 32.7 dBm 25.7 dBV rms Output 1 dB Compression Point VGAIN = 0.5 V 8.4 dBm 1.4 dBV rms f = 190 MHz Gain Maximum gain +43.5 dB Minimum gain −3.8 dB Gain Scaling Factor 19.6 mV/dB Gain Intercept −5.3 dB Noise Figure Maximum gain 7.5 dB Output IP3 f1 = 190 MHz, f2 = 191 MHz, VGAIN = 0.5 V 30.9 dBm 23.9 dBV rms Output 1 dB Compression Point VGAIN = 0.5 V 8.4 dBm 1.4 dBV rms f = 240 MHz Gain Maximum gain +43 dB Minimum gain −4.1 dB Gain Scaling Factor 19.7 mV/dB Gain Intercept −5.2 dB Noise Figure Maximum gain 7.6 dB Output IP3 f1 = 240 MHz, f2 = 241 MHz, VGAIN = 0.5 V 29.2 dBm 22.2 dBV rms Output 1 dB Compression Point VGAIN = 0.5 V 8.1 dBm 1.1 dBV rms 1 The output dc centering voltage is normally set at VS/2 and can be adjusted by applying a voltage to DECL. Rev. A | Page 4 of 24 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT ATTENUATOR AND GAIN CONTROL INPUT AND OUTPUT INTERFACES POWER AND VOLTAGE METRICS NOISE AND DISTORTION OUTPUT CENTERING RMS DETECTION APPLICATIONS INPUT AND OUTPUT MATCHING VGA OPERATION MODULATED GAIN MODE AGC OPERATION MODIFYING THE AGC SETPOINT EVALUATION BOARD CHARACTERIZATION SETUP AND METHODS OUTLINE DIMENSIONS ORDERING GUIDE
