LT1789-1/LT1789-10 ELECTRICAL CHARACTERISTICSThe l denotes the specifications which apply over the temperature range of–40°C ≤ TA ≤ 85°C. VS = ±15V, RL = 20k, VCM = VREF = 0V, unless otherwise noted. (Note 4)LT1789-1LT1789-10SYMBOL PARAMETERCONDITIONSMINTYPMAXMINTYPMAXUNITS PSRR Power Supply Rejection Ratio LT1789-1, VS = ±1.25V to ±16V LT1789-10, VS = ±1.50V to ±16V G = 1 l 90 dB G = 10 l 100 96 dB G = 100, 1000 l 102 102 dB Minimum Supply Voltage l ±1.25 ±1.50 V IS Supply Current l 160 160 µA VO Output Voltage Swing l ±14.15 ±14.15 V SR Slew Rate VOUT = ±10V l 0.008 0.024 V/µs Note 1: Stresses beyond those listed under Absolute Maximum Ratings Note 5: Hysteresis in offset voltage is created by package stress that may cause permanent damage to the device. Exposure to any Absolute differs depending on whether the IC was previously at a higher or lower Maximum Rating condition for extended periods may affect device temperature. Offset voltage hysteresis is always measured at 25°C, but reliability and lifetime. the IC is cycled to 85°C I-grade (or 70°C C-grade) or – 40°C I-grade Note 2: Does not include the effect of the external gain resistor R (0°C C-grade) before successive measurement. 60% of the parts will G. Note 3: This parameter is not 100% tested. pass the typical limit on the data sheet. Note 4: The LT1789C-1/ LT1789C-10 is guaranteed to meet specified Note 6: VS = 5V limits are guaranteed by correlation to VS = 3V and performance from 0°C to 70°C and is designed, characterized and VS = ±15V tests. expected to meet these extended temperature limits, but is not tested at Note 7: VS = 3V limits are guaranteed by correlation to VS = 5V and –40°C and 85°C. The LT1789I-1/ LT1789I-10 is guaranteed to meet the VS = ±15V tests. extended temperature limits. Note 8: This parameter is not tested at VS = 3V on the LT1789-10 due to an increase in sensitivity to test system noise. Actual performance is expected to be similar to performance at VS = 5V. TYPICAL PERFORMANCE CHARACTERISTICS (LT1789-1, LT1789-10)Input Bias CurrentInput Bias CurrentSupply Current vs Supply Voltagevs Temperaturevs Common Mode Input Voltage 120 0 –10 VS = 5V, 0V –55°C 110 V –12 CM = 2.5V 100 –5 –14 125°C 125°C 90 –16 80 –10 –18 25°C 25°C 70 –20 85°C 60 –55°C –15 –22 50 –24 SUPPLY CURRENT (μA) INPUT BIAS CURRENT (nA) INPUT BIAS CURRENT (nA) 40 –20 –26 30 –28 VS = 5V, 0V VREF = 2.5V 20 –25 –30 0 5 10 15 20 25 30 35 40 –50 –25 0 25 50 75 100 125 –0.5 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) COMMON MODE INPUT VOLTAGE (V) 1789 G01 1789 G02 1789 G03 1789fc 9
