Datasheet LT1102 (Analog Devices)
DescriptionHigh Speed, Precision, JFET Input Instrumentation Amplifier (Fixed Gain = 10 or 100)
Pages / Page12 / 1 — FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. Wideband …
File Format / SizePDF / 192 Kb
FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. Wideband Instrumentation Amplifier. with. 150mA Output Current. Slew Rate. FPO
Datasheet LT1102 Analog Devices
LT1102 High Speed, Precision, JFET Input Instrumentation Amplifier (Fixed Gain = 10 or 100)
U FEATURES DESCRIPTIO
■ Slew Rate: 30V/μs The LT®1102 is the first fast FET input instrumentation ■ Gain-Bandwidth Product: 35MHz amplifier offered in the low cost, space saving 8-pin ■ Settling Time (0.01%): 3μs packages. Fixed gains of 10 and 100 are provided with ■ Overdrive Recovery: 0.4μs excellent gain accuracy (0.01%) and non-linearity (3ppm). ■ Gain Error: 0.05% Max No external gain setting resistor is required. ■ Gain Drift: 5ppm/°C Slew rate, settling time, gain-bandwidth product, ■ Gain Nonlinearity: 16ppm Max overdrive recovery time are all improved compared to ■ Offset Voltage (Input + Output): 600μV Max competitive high speed instrumentation amplifiers. – Drift with Temperature: 2μV/°C ■ Input Bias Current: 40pA Max Industry best speed performance is combined with ■ Input Offset Current: 40pA Max impressive precision specifications: less than 10pA input – Drift with Temperature (to 70°C): 0.5pA/°C bias and offset currents, 180μV offset voltage. Unlike other FET input instrumentation amplifiers, on the LT1102
U
there is no output offset voltage contribution to total error,
APPLICATIO S
and input bias currents do not double with every 10°C rise in temperature. Indeed, at 70 ■ °C ambient temperature the Fast Settling Analog Signal Processing input bias current is only 40pA. ■ Multiplexed Input Data Acquisition Systems ■ High Source Impedance Signal Amplification from , LT, LTC and LTM are registered trademarks of Linear Technology Corporation. High Resistance Bridges, Capacitance Sensors, Photodetector Sensors ■ Bridge Amplifier with < 1Hz Lowpass Filtering
U TYPICAL APPLICATIO Wideband Instrumentation Amplifier with
150mA Output Current Slew Rate
V+ = 15V
FPO
R 5 6 BIAS + 7 8 LT1102 LT1010 OUT 5V/DIV 3 4 – 2 1 OUTPUT = ± 10V INTO 75Ω TO 330kHz (R = 50Ω) ± G = 10 0.5
FPO
LT1102 • TA02 μs/DIV 10V INTO 200Ω TO 330kHz (R = 200Ω) V – = – 15V DRIVES 2.2nF CAP LOAD GAIN = 10, DEGRADED 0.01% DUE TO LT1010 LT1102 • TA01 1102fb 1
