Datasheet LT6210, LT6211 (Analog Devices) - 4
DescriptionSingle Programmable Supply Current, R-R Output, Current Feedback Amplifiers
Pages / Page18 / 4 — e lecTrical characTerisTics (IS = 6mA per Amplifier) The. denotes the …
File Format / SizePDF / 354 Kb
e lecTrical characTerisTics (IS = 6mA per Amplifier) The. denotes the specifications which
e lecTrical characTerisTics (IS = 6mA per Amplifier) The denotes the specifications which
LT6210/LT6211
l
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. For V+ = 5V, V– = –5V: RSET = 20k to ground, AV = +2, RF = RG = 887Ω, RL = 150Ω; For V+ = 3V, V– = 0V: RSET = 0Ω to V–, AV = +2, RF = 887Ω, RG = 887Ω to 1.5V, RL = 150Ω to 1.5V unless otherwise specified. V+ = 5V, V– = –5V, IS = 6mA V+ = 3V, V– = 0V, IS = 6mA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
IOUT Maximum Output Current RL = 0Ω (Notes 7, 11) l ±75 ±45 mA R – OL Transimpedance, ∆VOUT/∆IIN VOUT = V+ – 1.2V to V– + 1.2V 65 115 65 115 kΩ SR Slew Rate (Note 8) 500 700 200 V/µs tpd Propagation Delay 50% VIN to 50% VOUT, 1.5 2.4 ns 100mV + – P-P, Larger of tpd , tpd BW –3dB Bandwidth <1dB Peaking, AV = 1 200 120 MHz ts Settling Time To 0.1% of VFINAL, VSTEP = 2V 20 25 ns tf, tr Small-Signal Rise and Fall Time 10% to 90%, VOUT = 100mVP-P 2 3.5 ns dG Differential Gain (Note 9) 0.20 0.35 % dP Differential Phase (Note 9) 0.10 0.20 Deg HD2 2nd Harmonic Distortion f = 1MHz, VOUT = 2VP-P –70 –65 dBc HD3 3rd Harmonic Distortion f = 1MHz, VOUT = 2VP-P –75 –75 dBc
(IS = 3mA per Amplifier) The
l
denotes the specifications which apply over the specified operating temperature range, otherwise specifications are at TA = 25°C. For V+ = 5V, V– = –5V: RSET = 56k to ground, AV = +2, RF = RG = 1.1k, RL = 150Ω; For V+ = 3V, V– = 0V: RSET = 10k to V–, AV = +2, RF = 1.27k, RG = 1.27k to 1.5V, RL = 150Ω to 1.5V unless otherwise specified. V+ = 5V, V– = –5V, IS = 3mA V+ = 3V, V– = 0V, IS = 3mA SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage –1 ±5.5 –1.5 ±5.5 mV l ±8.5 ±8.5 mV I + IN Noninverting Input Current –1.5 ±5 –1.5 ±5 µA l ±7 ±7 µA I – IN Inverting Input Current –12 ±36 –3 ±15 µA l ±52 ±20 µA en Input Noise Voltage Density f = 1kHz, RF = 1.1k, 7 7 nV/√Hz RG = 57.6Ω, RS = 0Ω +in Input Noise Current Density f = 1kHz 1.5 1.5 pA/√Hz –in Input Noise Current Density f = 1kHz 15 15 pA/√Hz R + IN Noninverting Input Resistance VIN = V+ – 1.2V to V– + 1.2V l 0.5 3 1 2.5 MΩ C + IN Noninverting Input Capacitance f = 100kHz 2 2 pF VINH Input Voltage Range, High (Note 10) l 3.8 4.1 1.8 2.1 V VINL Input Voltage Range, Low (Note 10) l –4.1 –3.8 0.9 1.2 V VOUTH Output Voltage Swing, High RL = 1k (Note 11) 4.8 2.9 V RL = 150Ω (Note 11) 4.3 4.6 2.6 2.8 V RL = 150Ω (Note 11) l 4.1 2.55 V VOUTL Output Voltage Swing, Low RL = 1k (Note 11) –4.95 0.05 V RL = 150Ω (Note 11) –4.8 –4.55 0.1 0.3 V RL = 150Ω (Note 11) l –4.4 0.35 V CMRR Common Mode Rejection Ratio VIN = V+ – 1.2V to V– + 1.2V 46 50 46 dB l 43 dB –ICMRR Inverting Input Current VIN = V+ – 1.2V to V– + 1.2V 0.3 ±1.5 0.4 µA/V Common Mode Rejection l ±2 µA/V 62101fc 4 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical AC Performance Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
