LT6210/LT6211 Typical perForMance characTerisTics (Supply Current Is Measured Per Amplifier)Input Noise Spectral DensityInput Noise Spectral DensityInput Noise Spectral Density(IS = 6mA per Amplifier)(IS = 3mA per Amplifier)(IS = 300µA per Amplifier) 100 100 100 VS = ±5V VS = ±5V VS = ±5V R R R ) L = 150Ω L = 150Ω L = 1k –i ) Hz n TA = 25°C Hz TA = 25°C Hz TA = 25°C –in e +i n n 10 e 10 en 10 OR pA/√ n OR pA/√ OR pA/√ Hz Hz Hz –in +in +in 1 1 1 INPUT NOISE (nV/√ INPUT NOISE (nV/√ INPUT NOISE (nV/√ 0.1 0.1 0.1 0.001 0.01 0.1 1 10 100 0.001 0.01 0.1 1 10 100 0.001 0.01 0.1 1 10 100 FREQUENCY (kHz) FREQUENCY (kHz) FREQUENCY (kHz) 62101GO4 62101GO5 62101GO6 Input Offset Voltage vs InputInput Common Mode Range vsInput Common Mode Range vsCommon Mode VoltageTemperatureTemperature 20 5.0 1.5 IS = 300µA 15 R IS = 300µA 4.5 F = 13.7k R 1.0 R L = 1k F = 13k 10 R I L = 1k S = 300µA RF = 13.7k 4.0 0.5 5 RL = 1k IS = 6mA IS = 3mA IS = 6mA IS = 3mA 0 IS = 3mA RF = 1200Ω RF = 1690Ω 0 RF = 1100Ω RF = 1540Ω RF = 1690Ω RL = 150Ω RL = 150Ω RL = 150Ω RL = 150Ω R –5 L = 150Ω –4.0 –0.5 OFFSET VOLTAGE (mV) –10 VS = ±5V I VS = ±5V I VS = ±1.5V I A S = 6mA S = 300µA INPUT COMMON MODE LIMIT (V) –4.5 A INPUT COMMON MODE LIMIT (V) –1.0 A S = 300µA –15 V = 1 R V = 1 R V = 1 R T F = 1200Ω F = 13.7k F = 13k A = 25°C R CMRR > 48dB R CMRR >46dB R TYPICAL PART L = 150Ω TYPICAL PART L = 1k TYPICAL PART L = 1k –20 –5.0 –1.5 –5 –4 –3 –2 –1 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 INPUT COMMON MODE VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 62101 G07 62101 G08 62101 G09 Output Voltage Swing vsOutput Voltage Swing vsTemperatureTemperatureOutput Voltage Swing vs ILOAD 5.0 1.5 5.0 4.8 1.4 4.8 OUTPUT HIGH OUTPUT HIGH I 1.3 4.6 S = 3mA 4.6 I I S = 6mA S = 6mA I I S = 300µA R 1.2 S = 300µA 4.4 4.4 L = 1k IS = 6mA R R L = 1k L = 1k IS = 6mA RL = 150Ω 1.1 RL = 100Ω 4.2 VS = ±5V VS = ±1.5V V 4.0 CM = 0V VCM = 0V IS = 300µA –4.4 ∆VOS = 50mV –1.1 ∆V 3.8 I OS = 50mV S = 6mA IS = 6mA OUTPUT VOLTAGE (V) R –1.2 3.6 –4.6 L = 150Ω OUTPUT VOLTAGE (V) R OUTPUT VOLTAGE (V) I IS = 300µA L = 100Ω S = 6mA IS = 300µA V R RL = 1k –1.3 S = ±5V L = 1k RL = 1k 3.4 V –4.8 CM = 0V ∆V OUTPUT LOW –1.4 3.2 OS = 50mV OUTPUT LOW T –5.0 –1.5 A = 25°C 3.0 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 0 10 20 30 40 50 60 70 TEMPERATURE (°C) TEMPERATURE (°C) LOAD CURRENT (mA) 6210 G10 6210 G11 6210 G12 62101fc 8 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical AC Performance Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
