Datasheet LT6210, LT6211 (Analog Devices) - 9
DescriptionSingle Programmable Supply Current, R-R Output, Current Feedback Amplifiers
Pages / Page18 / 9 — Typical perForMance characTerisTics (Supply Current Is Measured Per …
File Format / SizePDF / 354 Kb
Typical perForMance characTerisTics (Supply Current Is Measured Per Amplifier). Output Voltage Swing vs ILOAD
Typical perForMance characTerisTics (Supply Current Is Measured Per Amplifier) Output Voltage Swing vs ILOAD
LT6210/LT6211
Typical perForMance characTerisTics (Supply Current Is Measured Per Amplifier) Output Voltage Swing vs ILOAD Output Voltage Swing vs ILOAD Output Voltage Swing vs ILOAD
–3.0 VS = ±5V 1.4 VS = ±1.5V –0.1 –3.2 VCM = 0V VCM = 0V ∆V I ∆V –3.4 OS = 50mV S = 3mA OS = 50mV T 1.2 –0.3 A = 25°C IS = 6mA TA = 25°C –3.6 1.0 –0.5 –3.8 0.8 –0.7 –4.0 IS = 300µA –4.2 0.6 –0.9 I OUTPUT VOLTAGE (V) –4.4 S = 300µA OUTPUT VOLTAGE (V) 0.4 OUTPUT VOLTAGE (V) –1.1 V –4.6 IS = 300µA S = ±1.5V VCM = 0V 0.2 –1.3 IS = 3mA –4.8 IS = 3mA ∆VOS = 50mV I I S = 6mA S = 6mA TA = 25°C –5.0 0 –1.5 0 10 20 30 40 50 60 70 0 10 20 30 40 50 60 70 0 10 20 30 40 50 60 70 LOAD CURRENT (mA) LOAD CURRENT (mA) LOAD CURRENT (mA) 6210 G13 6210 G14 6210 G15
CMRR and PSRR vs Frequency CMRR and PSRR vs Frequency CMRR and PSRR vs Frequency (IS = 6mA per Amplifier) (IS = 3mA per Amplifier) (IS = 300µA per Amplifier)
70 70 70 –PSRR VS = ±5V VS = ±5V VS = ±5V R –PSRR R –PSRR R 60 L = 150Ω L = 150Ω L = 1k T 60 60 A = 25°C T T +PSRR A = 25°C +PSRR A = 25°C +PSRR 50 50 50 CMRR CMRR CMRR 40 40 40 30 30 30 REJECTION RATIO (dB) 20 REJECTION RATIO (dB) 20 REJECTION RATIO (dB) 20 10 10 10 0 0 0 0.001 0.01 0.1 1 10 100 0.001 0.01 0.1 1 10 100 0.001 0.01 0.1 1 10 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 6210 G16 6210 G17 6210 G18
Frequency Response vs Closed Frequency Response vs Closed Frequency Response vs Closed Loop Gain (IS = 300µA per Loop Gain (IS = 6mA per Amplifier) Loop Gain (IS = 3mA per Amplifier) Amplifier)
9 9 9 AV = 2 AV = 2 AV = 2 RF = RG = 887Ω RF = RG = 1100Ω RF = RG = 11k 6 6 6 3 3 3 AV = 1 GAIN (dB) 0 GAIN (dB) 0 GAIN (dB) 0 RF = 13.7k AV = 1 A V RF = 1.2k V V = –1 V AV = –1 –3 S = ±5V S = ±5V R S = ±5V R –3 F = RG = 1200Ω –3 R L = 150Ω RL = 150Ω RL = 150Ω F = RG = 10k T A A = 25°C V = –1 TA = 25°C A TA = 25°C V R V = 1 OUT = 100mVP-P F = RG = 698Ω VOUT = 100mVP-P RF = 1690Ω VOUT = 100mVP-P –6 –6 –6 0.1 1 10 100 1000 0.1 1 10 100 1000 0.1 1 10 100 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 6210 G19 6210 G20 6210 G21 62101fc 9 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical AC Performance Typical Performance Characteristics Applications Information Typical Applications Simplified Schematic Package Description Revision History Typical Application Related Parts
