LT1395/LT1396/LT1397 PIN FUNCTIONSLT1395CS5LT1397CS, LT1397CDE, LT1397HDEOUT (Pin 1): Output. OUT A (Pin 1): A Channel Output. V – (Pin 2): Negative Supply Voltage, Usually –5V. – IN A (Pin 2): Inverting Input of A Channel Amplifi er. +IN (Pin 3): Noninverting Input. + IN A (Pin 3): Noninverting Input of A Channel Amplifi er. – IN (Pin 4): Inverting Input. V + (Pin 4): Positive Supply Voltage, Usually 5V. V+ (Pin 5): Positive Supply Voltage, Usually 5V. + IN B (Pin 5): Noninverting Input of B Channel Amplifi er. – IN B (Pin 6): Inverting Input of B Channel Amplifi er. LT1395CS6OUT B (Pin 7): B Channel Output. OUT (Pin 1): Output. OUT C (Pin 8): C Channel Output. V – (Pin 2): Negative Supply Voltage, Usually –5V. – IN C (Pin 9): Inverting Input of C Channel Amplifi er. + IN (Pin 3): Noninverting Input. +IN C (Pin 10): Noninverting Input of C Channel Amplifi er. – IN (Pin 4): Inverting Input. V – (Pin 11): Negative Supply Voltage, Usually –5V. EN (Pin 5): Enable Pin. Logic low to enable. +IN D (Pin 12): Noninverting Input of D Channel Amplifi er. V+ (Pin 6): Positive Supply Voltage, Usually 5V. – IN D (Pin 13): Inverting Input of D Channel Amplifi er. LT1395CS8OUT D (Pin 14): D Channel Output. NC (Pin 1): No Connection. LT1397CGN– IN (Pin 2): Inverting Input. OUT A (Pin 1): A Channel Output. + IN (Pin 3): Noninverting Input. – IN A (Pin 2): Inverting Input of A Channel Amplifi er. V – (Pin 4): Negative Supply Voltage, Usually –5V. + IN A (Pin 3): Noninverting Input of A Channel Amplifi er. NC (Pin 5): No Connection. V+ (Pin 4): Positive Supply Voltage, Usually 5V. OUT (Pin 6): Output. + IN B (Pin 5): Noninverting Input of B Channel Amplifi er. V+ (Pin 7): Positive Supply Voltage, Usually 5V. – IN B (Pin 6): Inverting Input of B Channel Amplifi er. NC (Pin 8): No Connection. OUT B (Pin 7): B Channel Output. LT1396CMS8, LT1396CS8, LT1396CDDNC (Pin 8): No Connection. OUT A (Pin 1): A Channel Output. NC (Pin 9): No Connection. – IN A (Pin 2): Inverting Input of A Channel Amplifi er. OUT C (Pin 10): C Channel Output. + IN A (Pin 3): Noninverting Input of A Channel Amplifi er. – IN C (Pin 11): Inverting Input of C Channel Amplifi er. V – (Pin 4): Negative Supply Voltage, Usually –5V. +IN C (Pin 12): Noninverting Input of C Channel Amplifi er. + IN B (Pin 5): Noninverting Input of B Channel Amplifi er. V– (Pin 13): Negative Supply Voltage, Usually –5V. – IN B (Pin 6): Inverting Input of B Channel Amplifi er. +IN D (Pin 14): Noninverting Input of D Channel Amplifi er. OUT B (Pin 7): B Channel Output. – IN D (Pin 15): Inverting Input of D Channel Amplifi er. V + (Pin 8): Positive Supply Voltage, Usually 5V. OUT D (Pin 16): D Channel Output. 139567fd 9
