Datasheet LT1259, LT1260 (Analog Devices) - 2
DescriptionLow Cost Dual and Triple 130MHz Current Feedback Amplifiers with Shutdown
Pages / Page12 / 2 — ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL …
File Format / SizePDF / 337 Kb
ABSOLUTE AXI U RATI GS. PACKAGE/ORDER I FOR ATIO. ELECTRICAL CHARACTERISTICS. C, each amplifier VCM = 0V,
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO ELECTRICAL CHARACTERISTICS C, each amplifier VCM = 0V,
LT1259/LT1260
W W W U ABSOLUTE AXI U RATI GS
Supply Voltage ... ±18V Operating Temperature Range ... – 40°C to 85°C Input Current ... ±15mA Storage Temperature Range .. – 65°C to 150°C Output Short-Circuit Duration (Note 1) ... Continuous Junction Temperature (Note 4) .. 150°C Specified Temperature Range (Note 2) ... 0°C to 70°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
ORDER PART TOP VIEW ORDER PART TOP VIEW NUMBER –IN R 1 16 EN R NUMBER –IN A 1 14 EN A R A +IN R 2 15 OUT R +IN A 2 13 OUT A LT1259CN GND 3 14 V+ LT1260CN GND 3 12 V+ LT1259CS –IN G 4 13 EN G LT1260CS GND 4 11 GND G LT1259IN +IN G 5 12 OUT G LT1260IN GND 5 10 V– LT1259IS GND 6 11 V– LT1260IS +IN B 6 9 OUT B B +IN B 7 10 OUT B –IN B 7 8 EN B B –IN B 8 9 EN B N PACKAGE S PACKAGE N PACKAGE S PACKAGE 14-LEAD PLASTIC DIP 14-LEAD PLASTIC SOIC 16-LEAD PLASTIC DIP 16-LEAD PLASTIC SOIC TJMAX = 150°C, θJA = 70°C/W (N) TJMAX = 150°C, θJA = 70°C/W (N) TJMAX = 150°C, θJA = 110°C/W (S) TJMAX = 150°C, θJA = 100°C/W (S) Consult factory for Military grade parts.
ELECTRICAL CHARACTERISTICS 0
C
TA
70
5V
VS
15V, EN pins = 0V, pulse tested, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage TA = 25°C 2 12 mV ● 16 mV Input Offset Voltage Drift ● 30 µV/°C I + IN Noninverting Input Current TA = 25°C 0.5 3 µA ● 6 µA I – IN Inverting Input Current TA = 25°C 20 90 µA ● 120 µA en Input Noise Voltage Density f = 1kHz, RF = 1k, RG = 10Ω, RS = 0Ω 3.6 nV/√Hz + in Noninverting Input Noise Current Density f = 1kHz 1.3 pA/√Hz – in Inverting Input Noise Current Density f = 1kHz 45 pA/√Hz RIN Input Resistance VIN = ±13V, VS = ±15V ● 2 17 MΩ VIN = ±3V, VS = ±5V ● 2 25 MΩ CIN Input Capacitance Enabled 2 pF Disabled 4 pF COUT Output Capacitance Disabled 4.4 pF VIN Input Voltage Range VS = ±15V, TA = 25°C ±13 ±13.5 V ● ±12 V VS = ±5V, TA = 25°C ±3 ±3.5 V ● ±2 V 2
