Datasheet LT1206 (Analog Devices) - 2
Description250mA/60MHz Current Feedback Amplifier
Pages / Page18 / 2 — absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion …
File Format / SizePDF / 372 Kb
absoluTe MaxiMuM raTings (Note 1). pin conFiguraTion. orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LT1206
Supply Voltage .. ±18V Operating Temperature Range ...–40°C to 85°C Input Current .. ±15mA Junction Temperature ... 150°C Output Short-Circuit Duration (Note 2) ...Continuous Storage Temperature Range .. –65°C to 150°C Specified Temperature Range (Note 3) .. 0°C to 70°C Lead Temperature (Soldering, 10 sec) ...300°C
pin conFiguraTion
TOP VIEW TOP VIEW NC 1 8 V+ V+ 1 8 V+ –IN 2 7 OUT –IN 2 7 OUT +IN 3 6 V– +IN 3 6 V– S/D* 4 5 COMP S/D* 4 5 COMP N8 PACKAGE S8 PACKAGE 8-LEAD PLASTIC DIP 8-LEAD PLASTIC SO θJA = 100°C/W θJA = 60°C/W FRONT VIEW FRONT VIEW 7 OUT 7 OUT 6 V– 6 V– 5 COMP 5 COMP 4 V+ 4 V+ 3 S/D* 3 S/D* TAB IS 2 +IN TAB IS 2 +IN V+ 1 –IN V+ 1 –IN R PACKAGE T7 PACKAGE 7-LEAD PLASTIC DD 7-LEAD PLASTIC TO-220 θJA = 30°C/W θJA = 5°C/W
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC1206CN8#PBF LTC1206CN8#TRPBF LT1206 8-Lead Plastic DIP –40°C to 85°C LT1206CS8#PBF LT1206CS8#TRPBF 1206 8-Lead Plastic SO –40°C to 85°C LT1206CR#PBF LT1206CR#TRPBF LT1206 7-Lead Plastic DD –40°C to 85°C LT1206CT7#PBF LT1206CT7#TRPBF LT1206 7-Lead Plastic TO-220 –40°C to 85°C
LEAD BASED FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC1206CN8† LTC1206CN8#TR LT1206 8-Lead Plastic DIP –40°C to 85°C LT1206CS8** LT1206CS8#TR 1206 8-Lead Plastic SO –40°C to 85°C LT1206CR† LT1206CR#TR LT1206 7-Lead Plastic DD –40°C to 85°C LT1206CT7† LT1206CT7#TR LT1206 7-Lead Plastic TO-220 –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. **Ground shutdown pin for normal operation. †See Note 3. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/ 1206fb 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Small-Signal Bandwidth Typical Performance Characteristics Simplified Schematic Applications Information Package Description Revision History Related Parts
