Datasheet LT1206 (Analog Devices) - 3
Description250mA/60MHz Current Feedback Amplifier
Pages / Page18 / 3 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 372 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over the full operating
elecTrical characTerisTics The denotes the specifications which apply over the full operating
LT1206
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VCM = 0, ±5V ≤ VS ≤ 15V, pulse tested, VS/D = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage ±3 ±10 mV l ±15 mV Input Offset Voltage Drift l 10 µV/°C I + IN Noninverting Input Current ±2 ±8 µA l ±25 µA I – IN Inverting Input Current ±10 ±60 µA l ±100 µA en Input Noise Voltage Density f = 10kHz, RF = 1k, RG = 10Ω, RS = 0Ω 3.6 nV/√Hz +in Input Noise Current Density f = 10kHz, RF = 1k, RG = 10Ω, RS = 10k 2 pA/√Hz –in Input Noise Current Density f = 10kHz, RF = 1k, RG = 10Ω, RS = 10k 30 pA/√Hz RIN Input Resistance VIN = ±12V, VS = ±15V l 1.5 10 MΩ VIN = ±2V, VS = ±5V l 0.5 5 MΩ CIN Input Capacitance VS = ±15V 2 pF Input Voltage Range VS = ±15V l ±12 ±13.5 V VS = ±5V l ±2 ±3.5 V CMRR Common Mode Rejection Ratio VS = ±15V, VCM = ±12V l 55 62 dB VS = ±5V, VCM = ±2V l 50 60 dB Inverting Input Current Common Mode VS = ±15V, VCM = ±12V l 0.1 10 µA/V Rejection VS = ±5V, VCM = ±2V l 0.1 10 µA/V PSRR Power Supply Rejection Ratio VS = ±5V to ±15V l 60 77 dB Noninverting Input Current Power Supply VS = ±5V to ±15V l 30 500 nA/V Rejection Inverting Input Current Power Supply Rejection VS = ±5V to ±15V l 0.7 5 µA/V AV Large-Signal Voltage Gain VS = ±15V, VOUT = ±10V, RL = 50Ω l 55 71 dB VS = ±5V, VOUT = ±2V, RL = 25Ω l 55 68 dB R – OL Transresistance, ΔVOUT/ΔIIN VS = ±15V, VOUT = ±10V, RL = 50Ω l 100 260 kΩ VS = ±5V, VOUT = ±2V, RL = 25Ω l 75 200 kΩ VOUT Maximum Output Voltage Swing VS = ±15V, RL = 50Ω ±11.5 ±12.5 V l ±10.0 V VS = ±15V, RL = 25Ω ±2.5 ±3.0 V l ±2.0 V IOUT Maximum Output Current RL = 1Ω l 250 500 1200 mA IS Supply Current VS = ±15V, VS/D = 0V 20 30 mA l 35 mA Supply Current, RS/D = 51k (Note 4) VS = ±15V 12 17 mA Positive Supply Current, Shutdown VS = ±15V, VS/D = 15V l 200 µA Output Leakage Current, Shutdown VS = ±15V, VS/D = 15V l 10 µA SR Slew Rate (Note 5) AV = 2 400 900 V/µs Differential Gain (Note 6) VS = ±15V, RF = 560Ω, RG = 560Ω, RL = 30Ω 0.02 % Differential Phase (Note 6) VS = ±15V, RF = 560Ω, RG = 560Ω, RL = 30Ω 0.17 Deg BW Small-Signal Bandwidth VS = ±15V, Peaking ≤ 0.5dB, RF = RG = 620Ω, RL = 100Ω 60 MHz VS = ±15V, Peaking ≤ 0.5dB, RF = RG = 649Ω, RL = 50Ω 52 MHz VS = ±15V, Peaking ≤ 0.5dB, RF = RG = 698Ω, RL = 30Ω 43 MHz VS = ±15V, Peaking ≤ 0.5dB, RF = RG = 825Ω, RL = 10Ω 27 MHz
Note 1:
Note 3:
Commercial grade parts are designed to operate over the may cause permanent damage to the device. Exposure to any Absolute temperature range of –40°C to 85°C but are neither tested nor guaranteed Maximum Rating condition for extended periods may affect device beyond 0°C to 70°C. Industrial grade parts tested over –40°C to 85°C are reliability and lifetime. available on special request. Consult factory.
Note 2:
Applies to short circuits to ground only. A short circuit between
Note 4:
RS/D is connected between the shutdown pin and ground. the output and either supply may permanently damage the part when
Note 5:
Slew rate is measured at ±5V on a ±10V output signal while operated on supplies greater than ±10V. operating on ±15V supplies with RF = 1.5k, RG = 1.5k and RL = 400Ω.
Note 6:
NTSC composite video with an output level of 2V. 1206fb 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Small-Signal Bandwidth Typical Performance Characteristics Simplified Schematic Applications Information Package Description Revision History Related Parts
