Datasheet LT1223 (Analog Devices) - 4
Description100MHz Current Feedback Amplifier
Pages / Page16 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 258 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
LT1223
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at VS =
15V, VCM = 0V, – 55
C
TA
125
C, unless otherwise noted. LT1223M SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VCM = 0V ● ±1 ±5 mV I + IN Noninverting Input Current VCM = 0V ● ±1 ±5 µA I – IN Inverting Input Current VCM = 0V ● ±1 ±10 µA RIN Input Resistance VIN = ±10V ● 1 10 MΩ Input Voltage Range ● ±10 ±12 V CMRR Common Mode Rejection Ratio VCM = ±10V ● 56 63 dB Inverting Input Current Common Mode Rejection VCM = ±10V ● 30 100 nA/V PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V ● 68 80 dB Noninverting Input Current Power Supply Rejection VS = ±4.5V to ±15V ● 12 200 nA/V Inverting Input Current Power Supply Rejection VS = ±4.5V to ±15V ● 60 500 nA/V AV Large-Signal Voltage Gain RLOAD = 400Ω, VOUT = ±10V ● 70 89 dB ROL Transresistance, ∆VOUT/∆IIN– RLOAD = 400Ω, VOUT = ±10V ● 1.5 5 MΩ VOUT Maximum Output Voltage Swing RLOAD = 200Ω ● ±7 ±12 V IOUT Maximum Output Current RLOAD = 200Ω ● 35 60 mA IS Supply Current VIN = 0V ● 6 10 mA Supply Current, Shutdown Pin 8 Current = 200µA ● 2 4 mA
Note 1:
Absolute Maximum Ratings are those values beyond which the life of a device may be impaired.
Note 2:
A heat sink may be required.
Note 3:
Noninverting operation, VOUT = ±10V, measured at ±5V. 1223fb 4
