Datasheet LT1223 (Analog Devices) - 5
Description | 100MHz Current Feedback Amplifier |
Pages / Page | 16 / 5 — TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage,. … |
File Format / Size | PDF / 258 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. Supply Current vs Supply Voltage,. Supply Current vs Supply Voltage
LT1223
W U TYPICAL PERFOR A CE CHARACTERISTICS Supply Current vs Supply Voltage, Supply Current vs Supply Voltage Output Short Circuit-Current vs VIN = 0 (Operating) (Shutdown) Temperature
10 4 100 PIN 8 = 0V 90 125°C 8 80 3 25°C 25°C 70 6 125°C 60 –55°C 2 50 Y CURRENT (mA) 4 Y CURRENT (mA) T CIRCUIT CURRENT (mA) 40 –55°C 30 SUPPL SUPPL 1 2 20 OUTPUT SHOR 10 0 0 0 0 2 4 6 8 10 12 14 16 18 20 0 2 4 6 8 10 12 14 16 18 20 –50 –25 0 25 50 75 100 125 SUPPLY VOLTAGE (±V) SUPPLY VOLTAGE (±V) CASE TEMPERATURE (°C) LT1223 • TPC02 LT1223 • TPC03 LT1223 • TPC04
Input Common Mode Limit vs Temperature +IB vs Common Mode Voltage –IB vs Common Mode Voltage
V+ 5 10 V = ±15V S ± V = 15V S –1 4 8 125°C –2 V = 15V S 3 6 –55°C 2 4 –3 V = 5V 25°C S 1 2 –4 µA) µA) –55°C ( 0 ( 0 4 I B 125°C B –1 –I –2 25°C 3 –2 –4 COMMON MODE RANGE (V) 2 V = ±15V S V = ±5V –3 –6 S 1 –4 –8 V– –5 –10 –50 –25 0 25 50 75 100 125 –15 –10 –5 0 5 10 15 –15 –10 –5 0 5 10 15 TEMPERATURE (°C) COMMON MODE VOLTAGE (V) COMMON MODE VOLTAGE (V) LT1223 • TPC05 LT1223 • TPC06 LT1223 ∑ TPC07
Output Voltage Swing vs Output Voltage Swing vs VOS vs Common Mode Voltage Load Resistor Supply Voltage
20 20 20 V = 15V S ± VS = ±15V 15 15 125°C 15 125°C 10 10 25°C, –55°C 10 –55°C 25°C 5 5 5 125°C 0 TAGE SWING (V) 0 TAGE SWING (V) 0 V (mV) OS –5 25°C –5 –5 25°C –55°C –10 –10 25°C, –55°C –10 –55°C OUTPUT VOL OUTPUT VOL 125°C –15 –15 125°C –15 –20 –20 –20 –15 –10 –5 0 5 10 15 100 1000 10000 0 2 4 6 8 10 12 14 16 18 20 COMMON MODE VOLTAGE (V) LOAD RESISTOR ( ) Ω SUPPLY VOLTAGE (±V) LT1223 • TPC08 LT1223 • TPC09 LT1223 • TPC10 1223fb 5
