Datasheet LT1358, LT1359 (Analog Devices) - 3
Description | Dual and Quad 25MHz, 600V/µs Op Amps |
Pages / Page | 16 / 3 — ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. … |
File Format / Size | PDF / 489 Kb |
ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. VSUPPLY. MIN. TYP. MAX. UNITS
LT1358/LT1359
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage ±15V 0.2 0.6 mV ±5V 0.2 0.6 mV ±2.5V 0.3 0.8 mV IOS Input Offset Current ±2.5V to ±15V 40 120 nA IB Input Bias Current ±2.5V to ±15V 120 500 nA en Input Noise Voltage f = 10kHz ±2.5V to ±15V 8 nV/√Hz in Input Noise Current f = 10kHz ±2.5V to ±15V 0.8 pA/√Hz RIN Input Resistance VCM = ±12V ±15V 35 80 MΩ Input Resistance Differential ±15V 6 MΩ CIN Input Capacitance ±15V 3 pF Input Voltage Range + ±15V 12.0 13.4 V ±5V 2.5 3.5 V ±2.5V 0.5 1.1 V Input Voltage Range – ±15V –13.2 –12.0 V ±5V –3.3 – 2.5 V ±2.5V –0.9 – 0.5 V CMRR Common Mode Rejection Ratio VCM = ±12V ±15V 83 97 dB VCM = ±2.5V ±5V 78 84 dB VCM = ±0.5V ±2.5V 68 75 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 92 106 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V 20 65 V/mV VOUT = ±10V, RL = 500Ω ±15V 7 25 V/mV VOUT = ±2.5V, RL = 1k ±5V 20 45 V/mV VOUT = ±2.5V, RL = 500Ω ±5V 7 25 V/mV VOUT = ±2.5V, RL = 150Ω ±5V 1.5 6 V/mV VOUT = ±1V, RL = 500Ω ±2.5V 7 30 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V 13.3 13.8 ±V RL = 500Ω, VIN = ±40mV ±15V 12.5 13.0 ±V RL = 500Ω, VIN = ±40mV ±5V 3.5 4.0 ±V RL = 150Ω, VIN = ±40mV ±5V 3.0 3.3 ±V RL = 500Ω, VIN = ±40mV ±2.5V 1.3 1.7 ±V IOUT Output Current VOUT = ±12.5V ±15V 25 30 mA VOUT = ±3V ±5V 20 25 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V 30 42 mA SR Slew Rate AV = – 2, (Note 4) ±15V 300 600 V/µs ±5V 150 220 V/µs Full Power Bandwidth 10V Peak, (Note 5) ±15V 9.6 MHz 3V Peak, (Note 5) ±5V 11.7 MHz GBW Gain Bandwidth f = 200kHz, RL = 2k ±15V 18 25 MHz ±5V 15 22 MHz ±2.5V 20 MHz tr, tf Rise Time, Fall Time AV = 1, 10%-90%, 0.1V ±15V 8 ns ±5V 9 ns Overshoot AV = 1, 0.1V ±15V 27 % ±5V 27 % Propagation Delay 50% VIN to 50% VOUT, 0.1V ±15V 9 ns ±5V 11 ns ts Settling Time 10V Step, 0.1%, AV = –1 ±15V 115 ns 10V Step, 0.01%, AV = –1 ±15V 220 ns 5V Step, 0.1%, AV = –1 ±5V 110 ns 5V Step, 0.01%, AV = –1 ±5V 380 ns 135859fb 3
