Datasheet LT1358, LT1359 (Analog Devices) - 4
Description | Dual and Quad 25MHz, 600V/µs Op Amps |
Pages / Page | 16 / 4 — ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. … |
File Format / Size | PDF / 489 Kb |
ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. VSUPPLY. MIN. TYP. MAX. UNITS
LT1358/LT1359
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
Differential Gain f = 3.58MHz, AV = 2, RL = 1k ±15V 0.1 % ±5V 0.1 % Differential Phase f = 3.58MHz, AV = 2, RL = 1k ±15V 0.50 Deg ±5V 0.35 Deg RO Output Resistance AV = 1, f = 100kHz ±15V 0.3 Ω Channel Separation VOUT = ±10V, RL = 500Ω ±15V 100 113 dB IS Supply Current Each Amplifier ±15V 2.0 2.5 mA Each Amplifier ±5V 1.9 2.4 mA
denotes the specifications which apply over the temperature range 0
C
TA
70
VOS Input Offset Voltage ±15V ● 0.8 mV ±5V ● 0.8 mV ±2.5V ● 1.0 mV Input VOS Drift (Note 6) ±2.5V to ±15V ● 5 8 µV/°C IOS Input Offset Current ±2.5V to ±15V ● 180 nA IB Input Bias Current ±2.5V to ±15V ● 750 nA CMRR Common Mode Rejection Ratio VCM = ±12V ±15V ● 81 dB VCM = ±2.5V ±5V ● 77 dB VCM = ±0.5V ±2.5V ● 67 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V ● 90 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 1k ±15V ● 15 V/mV VOUT = ±10V, RL = 500Ω ±15V ● 5 V/mV VOUT = ±2.5V, RL = 1k ±5V ● 15 V/mV VOUT = ±2.5V, RL = 500Ω ±5V ● 5 V/mV VOUT = ±2.5V, RL = 150Ω ±5V ● 1 V/mV VOUT = ±1V, RL = 500Ω ±2.5V ● 5 V/mV VOUT Output Swing RL = 1k, VIN = ±40mV ±15V ● 13.2 ±V RL = 500Ω, VIN = ±40mV ±15V ● 12.2 ±V RL = 500Ω, VIN = ±40mV ±5V ● 3.4 ±V RL = 150Ω, VIN = ±40mV ±5V ● 2.8 ±V RL = 500Ω, VIN = ±40mV ±2.5V ● 1.2 ±V IOUT Output Current VOUT = ±12.2V ±15V ● 24.4 mA VOUT = ±2.8V ±5V ● 18.7 mA ISC Short-Circuit Current VOUT = 0V, VIN = ± 3V ±15V ● 25 mA SR Slew Rate AV = – 2, (Note 4) ±15V ● 225 V/µs ±5V ● 125 V/µs GBW Gain Bandwidth f = 200kHz, RL = 2k ±15V ● 15 MHz ±5V ● 12 MHz Channel Separation VOUT = ±10V, RL = 500Ω ±15V ● 98 dB IS Supply Current Each Amplifier ±15V ● 2.9 mA Each Amplifier ±5V ● 2.8 mA 135859fb 4
