Datasheet LT1010 (Analog Devices) - 5
Description | Fast ±150mA Power Buffer |
Pages / Page | 20 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Offset Voltage. Input Bias … |
File Format / Size | PDF / 704 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Output Offset Voltage. Input Bias Current. Voltage Gain. Output Resistance
LT1010
TYPICAL PERFORMANCE CHARACTERISTICS Output Offset Voltage Input Bias Current Input Bias Current
200 200 200 VIN = 0 VIN = 0 VS = ±15V RL = 75Ω 150 150 150 TJ = 125°C V+ = 38V V+ = 38V V– = –2V TJ = 25°C 100 V– = –2V 100 100 V+ = 2V T OFFSET VOLTAGE (mV) BIAS CURRENT (µA) V+ = 2V BIAS CURRENT (µA) J = –55°C 50 V– = –38V 50 V– = –38V 50 0 0 0 –50 0 50 100 150 –50 0 50 100 150 –150 –100 –50 0 50 100 150 TEMPERATURE (°C) TEMPERATURE (°C) OUTPUT CURRENT (mA) 1010 G10 1010 G11 1010 G12
Voltage Gain Output Resistance Output Noise Voltage
1.000 12 200 IOUT = 0 IOUT ≤ 150mA TJ = 25°C 10 VS = 40V 150 0.999 8 6 100 GAIN (V/V) VS = 4.5V 0.998 4 RS = 1k OUTPUT RESISTANCE (Ω) NOISE VOLTAGE (nV/√Hz) 50 2 RS = 50Ω 0.997 0 0 –50 0 50 100 150 –50 0 50 100 150 10 100 1k 10k TEMPERATURE (°C) TEMPERATURE (°C) FREQUENCY (Hz) 1010 G13 1010 G14 1010 G15
Positive Saturation Voltage Negative Saturation Voltage Supply Current
4 4 7 VIN = 0 IOUT = 0 I I BIAS = 0 L = 150mA IL = –150mA TJ = –55°C 3 3 6 TJ = 25°C 2 2 5 IL = 50mA IL = –50mA I T L = 5mA IL = –5mA SUPPLY CURRENT (mA) J = 125°C SATURATION VOLTAGE (V) 1 SATURATION VOLTAGE (V) 1 4 0 0 3 –50 0 50 100 150 –50 0 50 100 150 0 10 20 30 40 TEMPERATURE (°C) TEMPERATURE (°C) TOTAL SUPPLY VOLTAGE (V) 1010 G16 1010 G17 1010 G18 1010fe 5 Document Outline Fteatures Applications Description Typical Application Absolute Maximum Ratings Preconditioning Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Schematic Diagram Definition Of Terms Package Description Revision History Related Parts
