Datasheet LT6233, LT6233-10, LT6234, LT6235 (Analog Devices) - 4
Description | 60MHz, Rail-to-Rail Output, 1.9nV/√Hz, 1.2mA Op Amp Family |
Pages / Page | 24 / 4 — elecTrical characTerisTics. TA = 25°C, VS = 5V, 0V; VS = 3.3V, 0V; VCM = … |
File Format / Size | PDF / 792 Kb |
elecTrical characTerisTics. TA = 25°C, VS = 5V, 0V; VS = 3.3V, 0V; VCM = VOUT = half supply,
LT6233/LT6233-10 LT6234/LT6235
elecTrical characTerisTics TA = 25°C, VS = 5V, 0V; VS = 3.3V, 0V; VCM = VOUT = half supply, ENABLE = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
PSRR Power Supply Rejection Ratio VS = 3V to 10V 90 115 dB PSRR Match (Channel-to-Channel) (Note 6) VS = 3V to 10V 84 115 dB Minimum Supply Voltage (Note 7) 3 V VOL Output Voltage Swing Low (Note 8) No Load 4 40 mV ISINK = 5mA 75 180 mV VS = 5V, ISINK = 15mA 165 320 mV VS = 3.3V, ISINK = 10mA 125 240 mV VOH Output Voltage Swing High (Note 8) No Load 5 50 mV ISOURCE = 5mA 85 195 mV VS = 5V, ISOURCE = 15mA 220 410 mV VS = 3.3V, ISOURCE = 10mA 165 310 mV ISC Short-Circuit Current VS = 5V ±40 ±55 mA VS = 3.3V ±35 ±50 mA IS Supply Current per Amplifier 1.05 1.2 mA Disabled Supply Current per Amplifier ENABLE = V+ – 0.35V 0.2 10 µA IENABLE ENABLE Pin Current ENABLE = 0.3V –25 –75 µA VL ENABLE Pin Input Voltage Low 0.3 V VH ENABLE Pin Input Voltage High V+ – 0.35 V Output Leakage Current ENABLE = V+ – 0.35V, VO = 1.5V to 3.5V 0.2 10 µA tON Turn-On Time ENABLE = 5V to 0V, RL = 1k, VS = 5V 500 ns tOFF Turn-Off Time ENABLE = 0V to 5V, RL = 1k, VS = 5V 76 µs GBW Gain-Bandwidth Product Frequency = 1MHz, VS = 5V 55 MHz LT6233-10 320 MHz SR Slew Rate VS = 5V, A V = –1, RL = 1k, VO = 1.5V to 3.5V 10 15 V/µs LT6233-10, VS = 5V, AV = –10, RL = 1k, 80 V/µs VO = 1.5V to 3.5V FPBW Full-Power Bandwidth VS = 5V, VOUT = 3VP-P (Note 9) 1.06 1.6 MHz LT6233-10, HD2 = HD3 ≤ 1% 2.2 MHz tS Settling Time (LT6233, LT6234, LT6235) 0.1%, VS = 5V, VSTEP = 2V, AV = –1, RL = 1k 175 ns 623345fc 4 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
