Datasheet LT6233, LT6233-10, LT6234, LT6235 (Analog Devices) - 3
Description60MHz, Rail-to-Rail Output, 1.9nV/√Hz, 1.2mA Op Amp Family
Pages / Page24 / 3 — orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE …
File Format / SizePDF / 792 Kb
orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION. SPECIFIED TEMPERATURE RANGE
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT6233/LT6233-10 LT6234/LT6235
LT6233CS6#PBF LT6233CS6#TRPBF LTAFL 6-Lead Plastic TS0T-23 0°C to 70°C LT6233IS6#PBF LT6233IS6#TRPBF LTAFL 6-Lead Plastic TS0T-23 –40°C to 85°C LT6233CS6-10#PBF LT6233CS6-10#TRPBF LTAFM 6-Lead Plastic TS0T-23 0°C to 70°C LT6233IS6-10#PBF LT6233IS6-10#TRPBF LTAFM 6-Lead Plastic TS0T-23 –40°C to 85°C LT6234CS8#PBF LT6234CS8#TRPBF 6234 8-Lead Plastic SO 0°C to 70°C LT6234IS8#PBF LT6234IS8#TRPBF 6234I 8-Lead Plastic SO –40°C to 85°C LT6234CDD#PBF LT6234CDD#TRPBF LAET 8-Lead (3mm × 3mm) Plastic DFN 0°C to 70°C LT6234IDD#PBF LT6234IDD#TRPBF LAET 8-Lead (3mm × 3mm) Plastic DFN –40°C to 85°C LT6235CGN#PBF LT6235CGN#TRPBF 6235 16-Lead Narrow Plastic SSOP 0°C to 70°C LT6235IGN#PBF LT6235IGN#TRPBF 6235I 16-Lead Narrow Plastic SSOP –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on non-standard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
elecTrical characTerisTics TA = 25°C, VS = 5V, 0V; VS = 3.3V, 0V; VCM = VOUT = half supply, ENABLE = 0V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage LT6233S6, LT6233S6-10 100 500 µV LT6234S8, LT6235GN 50 350 µV LT6234DD 75 450 µV Input Offset Voltage Match 80 600 µV (Channel-to-Channel) (Note 6) IB Input Bias Current 1.5 3 µA IB Match (Channel-to-Channel) (Note 6) 0.04 0.3 µA IOS Input Offset Current 0.04 0.3 µA Input Noise Voltage 0.1Hz to 10Hz 220 nVP-P en Input Noise Voltage Density f = 10kHz, VS = 5V 1.9 3 nV/√Hz in Input Noise Current Density, Balanced Source f = 10kHz, VS = 5V, RS = 10k 0.43 pA/√Hz Input Noise Current Density, Unbalanced Source f = 10kHz, VS = 5V, RS = 10k 0.78 pA/√Hz Input Resistance Common Mode 22 MΩ Differential Mode 25 kΩ CIN Input Capacitance Common Mode 2.5 pF Differential Mode 4.2 pF AVOL Large-Signal Gain VS = 5V, VO = 0.5V to 4.5V, RL = 10k to VS/2 73 140 V/mV VS = 5V, VO = 0.5V to 4.5V, RL = 1k to VS/2 18 35 V/mV VS = 3.3V, VO = 0.65V to 2.65V, RL = 10k to VS/2 53 100 V/mV VS = 3.3V, VO = 0.65V to 2.65V, RL = 1k to VS/2 11 20 V/mV VCM Input Voltage Range Guaranteed by CMRR, VS = 5V, 0V 1.5 4 V Guaranteed by CMRR, VS = 3.3V, 0V 1.15 2.65 V CMRR Common Mode Rejection Ratio VS = 5V, VCM = 1.5V to 4V 90 115 dB VS = 3.3V, VCM = 1.15V to 2.65V 85 110 dB CMRR Match (Channel-to-Channel) (Note 6) VS = 5V, VCM = 1.5V to 4V 84 115 dB 623345fc 3 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts
