Datasheet LT6205, LT6206, LT6207 (Analog Devices) - 3
DescriptionQuad Single Supply 3V, 100MHz Video Op Amps
Pages / Page18 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over …
File Format / SizePDF / 267 Kb
ELECTRICAL CHARACTERISTICS. The. denotes specifi cations which apply over the specifi ed temperature
ELECTRICAL CHARACTERISTICS The denotes specifi cations which apply over the specifi ed temperature
LT6205/LT6206/LT6207
denotes specifi cations which apply over the specifi ed temperature range, otherwise specifi cations are at TA = 25°C. VS = 3V, 0V; VS = 5V, 0V; VCM = VOUT = 1V, unless otherwise noted. LT6205C/LT6206C/LT6207C LT6205I/LT6206I/LT6207I SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage 1 3.5 mV l 5 mV Input Offset Voltage Match 1 3 mV (Channel-to-Channel) (Note 5) l 4 mV Input Offset Voltage Drift (Note 6) l 7 15 μV/°C IB Input Bias Current l 10 30 μA IOS Input Offset Current l 0.6 3 μA Input Noise Voltage 0.1Hz to 10Hz 2 μVP-P en Input Noise Voltage Density f = 10kHz 9 nV/√Hz in Input Noise Current Density f = 10kHz 4 pA/√Hz Input Resistance VCM = 0V to V+ – 2V 1 MΩ Input Capacitance 2 pF CMRR Common Mode Rejection Ratio VCM = 0V to V+ – 2V l 78 90 dB Input Voltage Range l 0 V+ – 2 V PSRR Power Supply Rejection Ratio VS = 3V to 12V l 67 75 dB VCM = VOUT = 0.5V Minimum Supply Voltage VCM = 0.5V l 2.7 V AVOL Large-Signal Voltage Gain VS = 5V, VO = 0.5V to 4.5V, RL = 1k l 30 100 V/mV VS = 5V, VO = 1V to 3V, RL = 150Ω l 5 20 V/mV VS = 3V, VO = 0.5V to 2.5V, RL = 1k l 20 60 V/mV VOL Output Voltage Swing Low (Note 7) No Load, Input Overdrive = 30mV l 10 25 mV ISINK = 5mA l 75 150 mV VS = 5V, ISINK = 25mA l 300 500 mV VS = 3V, ISINK = 15mA l 200 350 mV VOH Output Voltage Swing High (Note 7) No Load, Input Overdrive = 30mV l 60 100 mV ISOURCE = 5mA l 150 250 mV VS = 5V, ISOURCE = 25mA l 650 1200 mV VS = 3V, ISOURCE = 15mA l 300 500 mV ISC Short-Circuit Current VS = 5V, Output Shorted to GND 35 60 mA l 20 mA VS = 3V, Output Shorted to GND 30 50 mA l 20 mA IS Supply Current per Amplifi er 3.75 5 mA l 5.75 mA GBW Gain Bandwidth Product f = 2MHz l 65 100 MHz SR Slew Rate VS = 5V, AV = 2, RF = RG = 1k 450 V/μs VO = 1V to 4V, Measured from 1.5V to 3.5V Channel Separation f = 10MHz 90 dB FPBW Full Power Bandwidth VOUT = 2VP-P (Note 8) 71 MHz ts Settling Time to 3% VS = 5V, ΔVOUT = 2V, AV = –1, RL = 150Ω 15 ns Settling Time to 1% 25 ns Differential Gain VS = 5V, AV = 2, RL = 150Ω, Output Black Level = 1V 0.05 % Differential Phase VS = 5V, AV = 2, RL = 150Ω, Output Black Level = 1V 0.08 Deg 620567fc 3 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION TYPICAL APPLICATION PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
