Datasheet LT6552 (Analog Devices) - 5
Description3.3V Single Supply Video Difference Amplifier
Pages / Page16 / 5 — 5V ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 364 Kb
5V ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating
5V ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating
LT6552
C. VS = 5V, 0V. Figure 1 shows the DC test circuit, VREF = VCM = 1V, VDIFF = 0V, VSHDN = V+, unless otherwise noted. RL = RF + RG = 1k. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
tON Turn-On Time VSHDN from 0.5V to 4.7V 250 ns tOFF Turn-Off Time VSHDN from 4.7V to 0.5V 450 ns Shutdown Output Leakage Current VSHDN = 0.5V, 0V ≤ VOUT ≤ V+ ● 0.25 µA ±
denotes the specifications which apply over the full operat- ing temperature range, otherwise specifications are at TA = 25
C. VS =
5V. Figure 2 shows the DC test circuit, VREF = VCM = 0V, VDIFF = 0V, VSHDN = V+, unless otherwise noted. RL = RF + RG = 1k. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage Both Inputs (Note 7) 10 25 mV ● 30 mV ∆VOS/∆T Input VOS Drift ● 50 µV/°C IB Input Bias Current Any Input ● 25 50 µA IOS Input Offset Current Either Input Pair ● 1 5 µA en Input Noise Voltage Density f = 10kHz 55 nV/√Hz in Input Noise Current Density f = 10kHz 0.7 pA/√Hz RIN Input Resistance Common Mode, VCM = –5V to 3V 300 kΩ CMRR Common Mode Rejection Ratio VCM = –5V to 3V ● 58 75 dB Input Range ● –5 3 V PSRR Power Supply Rejection VS = ±2V to ±6V, VCM = 0V ● 48 54 dB GE Gain Error VO = –3V to 3V, RL = 1k ● 1 3 % RL = 150Ω ● 1 3 % Output Voltage Swing (VDIFF = ± 0.6V), VREF (Pin 1) = 0V, AV = 10 RL = 1k ● ±4.8 ±4.875 V RL = 150Ω ● ±3.6 ±4.3 V RL = 75Ω, 0°C ≤ TA ≤ 70°C (Only) ● ±2.75 ±3.4 V SR Slew Rate VCM = 0V, VDIFF = –1.5V to +1.5V, 400 600 V/µs VO = –5V to 5V Measure from –2V to 2V, RL = 150Ω FPBW Full-Power Bandwidth VO = 6VP-P (Note 9) 30 MHz BW Small-Signal –3dB Bandwidth AV = 2, RL = 150Ω 75 MHz tr, tf Rise Time, Fall Time AV = 50, VO = –3V to 3V, 20% to 80% 125 175 ns tS Settling Time to 3% AV = 2, ∆VOUT = 6V, Positive Step 25 ns Settling Time to 1% RL = 150Ω 35 ns Differential Gain AV = 2, RL = 150Ω, Output Black Level = 0V 0.2 % Differential Phase AV = 2, RL = 150Ω, Output Black Level = 0V 0.15 Deg ISC Short-Circuit Current VOUT = 0V, VDIFF = ±1V 50 70 mA 0°C ≤ TA ≤ 70°C ● 45 mA –40°C ≤ TA ≤ 85°C ● 35 mA Supply Current Shutdown VSHDN = –4.5V ● 650 1400 µA IS Supply Current 14 16.5 mA ● 18.5 mA VL Shutdown Pin Input Low Voltage ● –4.5 V VH Shutdown Pin Input High Voltage ● 4.7 V 6552f 5
