Datasheet LT6552 (Analog Devices) - 7
Description3.3V Single Supply Video Difference Amplifier
Pages / Page16 / 7 — TYPICAL PERFOR A CE CHARACTERISTICS. Input Bias Current vs Common. Supply …
File Format / SizePDF / 364 Kb
TYPICAL PERFOR A CE CHARACTERISTICS. Input Bias Current vs Common. Supply Current vs Supply Voltage
TYPICAL PERFOR A CE CHARACTERISTICS Input Bias Current vs Common Supply Current vs Supply Voltage
LT6552
W U TYPICAL PERFOR A CE CHARACTERISTICS Input Bias Current vs Common Supply Current vs Supply Voltage Input Bias Current vs Temperature Mode Voltage
20 –10 –4 VS = 5V, 0V VS = 5V, 0V 18 VCM = 1V –6 T –12 A = 125°C 16 –8 µA) µA) 14 –14 –10 TA = –55°C TA = 125°C 12 –12 –16 TA = 25°C T 10 –14 A = 25°C –18 8 –16 TA = –55°C 6 –20 –18 SUPPLY CURRENT (mA) INPUT BIAS CURRENT ( INPUT BIAS CURRENT ( 4 –20 –22 2 –22 0 –24 –24 0 2 4 6 8 10 12 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 TOTAL SUPPLY VOLTAGE (V) TEMPERATURE (°C) COMMON MODE VOLTAGE (V) 6552 G01 6552 G02 6552 G03
Output Saturation Voltage vs Output Saturation Voltage vs Supply Current vs Load Current (Output High) Load Current (Output Low) Shutdown Pin Voltage
1 1 16 V V S = 5V, 0V VS = 5V, 0V S = 5V, 0V TA = 125°C V 14 CM = 1V TA = 25°C 12 100m TA = –55°C 10 TA = 125°C 100m 8 TA = 25°C TA = 125°C 6 10m TA = –55°C SUPPLY CURRENT (mA) T 4 T A = 25°C A = –55°C 2 OUTPUT HIGH SATURATION VOLTAGE (V) OUTPUT LOW SATURATION VOLTAGE (V) 10m 1m 0 0.01 0.1 1 10 100 0.01 0.1 1 10 100 2.5 3.0 3.5 4.0 4.5 5.0 SOURCING LOAD CURRENT (mA) SINKING LOAD CURRENT (mA) SHUTDOWN PIN VOLTAGE (V) 6552 G04 6552 G05 6552 G06
Shutdown Pin Current vs Output Short-Circuit Current vs Output Short-Circuit Current vs Shutdown Pin Voltage Temperature Temperature
0 75 80 VS = 5V, 0V VS = ±5V VCM = 1V 70 VS = 5V, 0V SOURCING CURRENT –10 µA) 75 T 65 A = 125°C –20 60 SINKING CURRENT –30 70 55 TA = 25°C VS = 3.3V, 0V –40 50 T 65 A = –55°C SHUTDOWN PIN CURRENT ( –50 45 OUTPUT SHORT-CIRCUIIT CURRENT (mA) OUTPUT SHORT-CIRCUIIT CURRENT (mA) 40 –60 60 0 1 2 3 4 5 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 SHUTDOWN PIN VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 6552 G08 6552 G07 6552 G09 6552f 7
