DatasheetLT6200, LT6200-5 LT6200-10, LT6201 (Analog Devices) - 5
Description165MHz, Rail-to-Rail Input and Output, 0.95nV/√Hz Low Noise, Op Amp Family
Pages / Page26 / 5 — elecTrical characTerisTics. The. denotes the specifications which apply …
File Format / SizePDF / 548 Kb
elecTrical characTerisTics. The. denotes the specifications which apply over 0°C < TA < 70°C
elecTrical characTerisTics The denotes the specifications which apply over 0°C < TA < 70°C
LT6200/LT6200-5 LT6200-10/LT6201
denotes the specifications which apply over 0°C < TA < 70°C temperature range. VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, VSHDN = OPEN, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
AVOL Large-Signal Gain VS = 5V, VO = 0.5V to 4.5V,RL = 1k to VS/2 l 46 80 V/mV VS = 5V, VO = 1.5V to 3.5V,RL = 100Ω to VS/2 l 7.5 13 V/mV VS = 3V, VO = 0.5V to 2.5V,RL = 1k to VS/2 l 13 22 V/mV CMRR Common Mode Rejection Ratio VS = 5V, VCM = V– to V+ l 64 88 dB VS = 5V, VCM = 1.5V to 3.5V l 80 105 dB VS = 3V, VCM = V– to V+ l 60 83 dB CMRR Match (Channel-to-Channel) (Note 11) VS = 5V, VCM = 1.5V to 3.5V l 80 105 dB PSRR Power Supply Rejection Ratio VS = 3V to 10V, LT6201DD VS = 3V to 7V l 60 65 dB PSRR Match (Channel-to-Channel) (Note 11) VS = 3V to 10V, LT6201DD VS = 3V to 7V l 60 100 dB Minimum Supply Voltage (Note 6) l 3 V VOL Output Voltage Swing LOW (Note 7) No Load l 12 60 mV ISINK = 5mA l 55 110 mV VS = 5V, ISINK = 20mA l 170 310 mV VS = 3V, ISINK = 20mA l 170 310 mV VOH Output Voltage Swing HIGH (Note 7) No Load l 65 120 mV ISOURCE = 5mA l 115 210 mV VS = 5V, ISOURCE = 20mA l 260 440 mV VS = 3V, ISOURCE = 20mA l 270 490 mV ISC Short-Circuit Current VS = 5V l ±60 ±90 mA VS = 3V l ±45 ±75 mA IS Supply Current per Amplifier VS = 5V l 20 23 mA VS = 3V l 19 22 mA Disabled Supply Current per Amplifier VSHDN = 0.3V l 1.35 1.8 mA ISHDN SHDN Pin Current VSHDN = 0.3V l 215 295 µA VL VSHDN Pin Input Voltage LOW l 0.3 V VH VSHDN Pin Input Voltage HIGH l V+–0.5 V Shutdown Output Leakage Current VSHDN = 0.3V l 0.1 75 µA tON Turn-On Time VSHDN = 0.3V to 4.5V, RL = 100Ω, VS = 5V l 180 ns tOFF Turn-Off Time VSHDN = 4.5V to 0.3V, RL = 100Ω, VS = 5V l 180 ns SR Slew Rate VS = 5V, AV = –1, RL = 1k, VO = 4V LT6200, LT6201 l 29 42 V/µs VS = 5V, AV = –10, RL = 1k, VO = 4V LT6200-5 l 190 V/µs LT6200-10 l 310 V/µs FPBW Full Power Bandwidth (Note 9) VS = 5V, VOUT = 3VP-P (LT6200) l 3.07 4.45 MHz
The
denotes the specifications which apply over –40°C < TA < 85°C temperature range. Excludes the LT6201 in the DD package (Note 3). VS = 5V, 0V; VS = 3V, 0V; VCM = VOUT = half supply, VSHDN = OPEN, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage VS = 5V, VCM = Half Supply l 0.2 1.5 mV VS = 3V, VCM = Half Supply l 1 2.8 mV VS = 5V, VCM = V+ to V – l 0.3 3.5 mV VS = 3V, VCM = V+ to V – l 1.5 4.3 mV Input Offset Voltage Match VCM = Half Supply l 0.2 2 mV (Channel-to-Channel) (Note 11) VCM = V– to V+ l 0.4 3 mV VOS TC Input Offset Voltage Drift (Note 8) VCM = Half Supply l 2.5 8 µV/ºC IB Input Bias Current VCM = Half Supply l –40 –10 µA VCM = V+ l 8 18 µA VCM = V– l –50 –23 µA 62001ff 5 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Applications Information Package Description Revision History Typical Application Related Parts
