Datasheet LT1722, LT1723, LT1724 (Analog Devices) - 6
DescriptionQuad 200MHz Low Noise Precision Op Amps
Pages / Page18 / 6 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 306 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the temperature range of
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the temperature range of
LT1722/LT1723/LT1724
denotes the specifi cations which apply over the temperature range of 0°C ≤ T A ≤ 70°C. VS = 5V, VCM = 2.5V, RL to 2.5V, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 6) l 850 μV LT1722 SOT-23 and LT1723 MS8 l 950 μV Input VOS Drift (Note 9) l 3 7 μV/°C IOS Input Offset Current l 350 nA IB Input Bias Current l 350 nA Input Voltage Range + l 3.5 V Input Voltage Range – l 1.5 V CMRR Common Mode Rejection Ratio VCM = 1.5V to 3.5V l 75 dB AVOL Large-Signal Voltage Gain VOUT = 1.5V to 3.5V, RL = 500Ω l 3 V/mV VOUT Output Swing+ RL = 500Ω, VIN = ±10mV l 3.55 V Output Swing– RL = 500Ω, VIN = ±10mV l 1.45 V IOUT Output Current VOUT = 3.5V, or 1.5V, 10mV Overdrive l 9 mA ISC Short-Circuit Current VOUT = 2.5V, VIN = ±1V l 11 mA SR Slew Rate AV = –1, (Note 7) l 30 V/μs GBW Gain Bandwidth (Note 10) f = 200kHz l 100 MHz Channel Separation VOUT = 1.5V to 3.5V, RL = 500Ω l 81 dB IS Supply Current l 5.95 mA
The
denotes the specifi cations which apply over the temperature range of –40°C ≤ T A ≤ 85°C. VS = ±5V, VCM = 0V, unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 6) l 900 μV LT1722 SOT-23 and LT1723 MS8 l 1100 μV Input VOS Drift (Note 9) l 3 10 μV/°C IOS Input Offset Current l 400 nA IB Input Bias Current l 400 nA Input Voltage Range + l 3.5 V Input Voltage Range – l –3.5 V CMRR Common Mode Rejection Ratio VCM = ±3.5V l 75 dB PSRR Power Supply Rejection Ratio VS = ±2.0V to ±5.5V l 75 dB AVOL Large-Signal Voltage Gain VOUT = ±3V, RL = 500Ω l 8 V/mV VOUT = ±3V, RL = 150Ω l 5 V/mV VOUT Output Swing RL = 500Ω, VIN = ±10mV l ±3.1 V RL = 150Ω, VIN = ±10mV l ±3.0 V IOUT Output Current VOUT = ±3V, 10mV Overdrive l 20 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±1V l 25 mA SR Slew Rate AV = –1, (Note 7) l 25 V/μs GBW Gain Bandwidth f = 200kHz l 90 MHz Channel Separation VOUT = ±3V, RL = 150Ω l 80 dB IS Supply Current l 5.95 mA 172234fb 6
