Datasheet LT1722, LT1723, LT1724 (Analog Devices) - 8
DescriptionQuad 200MHz Low Noise Precision Op Amps
Pages / Page18 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Input Common Mode Range. Input Bias …
File Format / SizePDF / 306 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Input Common Mode Range. Input Bias Current. Supply Current vs Temperature
TYPICAL PERFORMANCE CHARACTERISTICS Input Common Mode Range Input Bias Current Supply Current vs Temperature
LT1722/LT1723/LT1724
TYPICAL PERFORMANCE CHARACTERISTICS Input Common Mode Range Input Bias Current Supply Current vs Temperature vs Supply Voltage vs Common Mode Voltage
5.0 0.5 400 PER AMPLIFIER V V+ S = ±5V 300 4.5 –0.5 –1.0 200 TA = 85°C VS = 5V 4.0 –1.5 TA = 25°C V 100 S = ±5V –1.2 T T A = –45°C A = 25°C 3.5 0 Y CURRENT (mA) TA = 125°C (VOS) < 500μV –100 3.0 2.0 SUPPL 1.5 INPUT BIAS CURRENT (nA) –200 2.5 INPUT COMMON MODE RANGE (V) 1.0 –300 0.5 2.0 V– –400 –50 –25 0 25 50 75 100 125 0 1 2 3 4 5 6 7 –5 –4 –3 –2 –1 0 1 2 3 4 5 TEMPERATURE (°C) SUPPLY VOLTAGE (±V) INPUT COMMON MODE VOLTAGE (V) 1723 G01 1723 G02 1723 G03
Input Bias Current Open-Loop Gain vs Temperature Input Noise Spectral Density vs Resistive Load
60 100 10 89.0 TA = 25°C INPUT CURRENT NOISE (pA/√ 40 ) Hz 86.5 VS = ±5V, VO = ±3V 20 84.0 VS = 5V I – i B n 0 10 1 81.5 VS = ±2.5V, VO = ±1V I + B –20 en 79.0 I – B OPEN-LOOP GAIN (dB) INPUT BIAS CURRENT (nA) Hz I + B –40 INPUT VOLTAGE NOISE (nV/√ ) 76.5 VS = ±5V –60 1 0.1 74.0 –50 –25 0 25 50 75 100 125 0.01 0.1 1 10 100 100 1000 10000 TEMPERATURE (°C) FREQUENCY (kHz) LOAD RESISTANCE (Ω) 1723 G04 1723 G05 1723 G06
Total Noise vs Unmatched Source Resistance Warm-Up Drift vs Time VOS Shift vs VCM and VS
100 30 300 VS = ±5V LT1722S8 V TA = 25°C T S = ±6.3V A = 25°C TA = 25°C TYPICAL PART ) f = 10kHz Hz 25 TYPICAL DATA 200 VS = ±6V TOTAL NOISE VS = ±5V 10 20 100 VS = ±5V RESISTOR NOISE VS = ±4V 15 0 VS = ±2.5V SHIFT (μV) VS = ±3V OS 1 10 V–100 VS = ±2.5V RS + OFFSET VOLTAGE DRIFT (μV) TOTAL NOISE VOLTAGE (nV/√ 5 –200 – 0.1 0 –300 0.01 0.1 1 10 100 0 10 20 30 40 50 60 70 80 90 100 –5 –4 –3 –2 –1 0 1 2 3 4 5 SOURCE RESISTANCE, RS (kΩ) TIME AFTER POWER-UP (SEC) COMMON MODE VOLTAGE (V) 1723 G07 1723 G08 1723 G09 172234fb 8
