Datasheet LT1468 (Analog Devices) - 4
Description | 90MHz, 22V/us 16-Bit Accurate Operational Amplifier |
Pages / Page | 16 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply … |
File Format / Size | PDF / 228 Kb |
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
LT1468
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
ts Settling Time 10V Step, 0.01%, AV = –1 ±15V 760 ns 10V Step, 150μV, AV = –1 ±15V 900 ns 5V Step, 0.01%, AV = –1 ±5V 770 ns RO Output Resistance AV = 1, f = 100kHz ±15V 0.02 Ω IS Supply Current ±15V 3.9 5.2 mA ±5V 3.6 5.0 mA
The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. 0°C ≤ TA ≤ 70°C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage N8, S8 ±15V ● 150 μV ± 5V ● 250 μV LT1468A, DD Package ±15V ● 150 μV ± 5V ● 250 μV LT1468, DD Package ±15V ● 300 μV ± 5V ● 400 μV Input VOS Drift (Note 7) ±5V to ±15V ● 0.7 2.0 μV/°C IOS Input Offset Current ±5V to ±15V ● 65 nA Input Offset Current Drift ±5V to ±15V 60 pA/°C I – B Inverting Input Bias Current ±5V to ±15V ● ±15 nA Negative Input Current Drift ± 5V to ±15V 40 pA/°C I + B Noninverting Input Bias Current ±5V to ±15V ● ±50 nA CMRR Common Mode Rejection Ratio VCM = ±12.5V ±15V ● 94 dB VCM = ±2.5V ±5V ● 94 dB PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V ● 98 dB AVOL Large-Signal Voltage Gain VOUT = ±12.5V, RL = 10k ±15V ● 500 V/mV VOUT = ±12.5V, RL = 2k ±15V ● 250 V/mV VOUT = ±2.5V, RL = 10k ±5V ● 500 V/mV VOUT = ±2.5V, RL = 2k ±5V ● 250 V/mV VOUT Output Swing RL = 10k ±15V ● ±12.9 V RL = 2k ±15V ● ±12.7 V RL = 10k ±5V ● ±2.9 V RL = 2k ±5V ● ±2.7 V IOUT Output Current VOUT = ±12.5V ±15V ● ±12.5 mA VOUT = ±2.5V ±5V ● ±12.5 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±0.2V ±15V ● ±17 mA SR Slew Rate AV = –1, RL = 2k (Note 5) ±15V ● 13 V/μs ±5V ● 9 V/μs GBW Gain Bandwidth f = 100kHz, RL = 2k ±15V ● 55 MHz ± 5V ● 50 MHz IS Supply Current ±15V ● 6.5 mA ±5V ● 6.3 mA 1468fb 4
