Datasheet LT1468 (Analog Devices) - 5
Description90MHz, 22V/us 16-Bit Accurate Operational Amplifier
Pages / Page16 / 5 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 228 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1468
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. –40°C ≤ TA ≤ 85°C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage N8, S8 ±15V ● 230 μV ± 5V ● 330 μV LT1468A, DD Package ±15V ● 230 μV ± 5V ● 330 μV LT1468, DD Package ±15V ● 400 μV ± 5V ● 500 μV Input VOS Drift (Note 7) ±5V to ±15V ● 0.7 2.5 μV/°C IOS Input Offset Current ±5V to ±15V ● 80 nA Input Offset Current Drift ±5V to ±15V 120 pA/°C I – B Inverting Input Bias Current ±5V to ±15V ● ±30 nA Negative Input Current Drift ±5V to ±15V 80 pA/°C I + B Noninverting Input Bias Current ±5V to ±15V ● ±60 nA CMRR Common Mode Rejection Ratio VCM = ±12.5V ±15V ● 92 dB VCM = ±2.5V ±5V ● 92 dB PSRR Power Supply Rejection Ratio VS = ±4.5V to ±15V ● 96 dB AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 10k ±15V ● 300 V/mV VOUT = ±10V, RL = 2k ±15V ● 150 V/mV VOUT = ±2.5V, RL = 10k ±5V ● 300 V/mV VOUT = ±2.5V, RL = 2k ±5V ● 150 V/mV VOUT Output Swing RL = 10k ±15V ● ±12.8 V RL = 2k ±15V ● ±12.6 V RL = 10k ±5V ● ±2.8 V RL = 2k ±5V ● ±2.6 V IOUT Output Current VOUT = ±12.5V ±15V ● ±7 mA VOUT = ±2.5V ±5V ● ±7 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±0.2V ±15V ● ±12 mA SR Slew Rate AV = –1, RL = 2k (Note 5) ±15V ● 9 V/μs ±5V ● 6 V/μs GBW Gain Bandwidth f = 100kHz, RL = 2k ±15V ● 45 MHz ±5V ● 40 MHz IS Supply Current ±15V ● 7.0 mA ±5V ● 6.8 mA
Note 1:
Note 4
: The LT1468C is guaranteed to meet specifi ed performance from may cause permanent damage to the device. Exposure to any Absolute 0°C to 70°C and is designed, characterized and expected to meet these Maximum Rating condition for extended periods may affect device extended temperature limits, but is not tested at – 40°C and at 85°C. The reliability and lifetime. LT1468I is guaranteed to meet the extended temperature limits.
Note 2
: The inputs are protected by back-to-back diodes and two 100Ω
Note 5
: Slew rate is measured between ±8V on the output with ±12V input series resistors. If the differential input voltage exceeds 0.7V, the input for ±15V supplies and ±2V on the output with ±3V input for ±5V supplies. current should be limited to 10mA. Input voltages outside the supplies will
Note 6
: Full power bandwidth is calculated from the slew rate be clamped by ESD protection devices and input currents should also be measurement: FPBW = SR/2πVP limited to 10mA.
Note 7
: This parameter is not 100% tested.
Note 3
: A heat sink may be required to keep the junction temperature below absolute maximum when the output is shorted indefi nitely. 1468fb 5
