Datasheet LT1360 (Analog Devices) - 2
Description50MHz, 800V/µs Op Amp
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL …
File Format / SizePDF / 229 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS TA = 25
ABSOLUTE MAXIMUM RATINGS (Note 1) PACKAGE/ORDER INFORMATION ELECTRICAL CHARACTERISTICS TA = 25
LT1360
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Total Supply Voltage (V+ to V–) ... 36V Operating Temperature Range (Note 8) ...–40°C to 85°C Differential Input Voltage Specified Temperature Range (Note 9) ..–40°C to 85°C (Transient Only) (Note 2)... ±10V Maximum Junction Temperature (See Below) Input Voltage .. ±VS Plastic Package .. 150°C Output Short Circuit Duration (Note 3) .. Indefinite Storage Temperature Range ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW ORDER PART TOP VIEW ORDER PART NULL 1 8 NULL NUMBER NULL 1 8 NULL NUMBER –IN 2 7 V+ –IN 2 7 V+ LT1360CN8 LT1360CS8 +IN 3 6 VOUT +IN 3 6 VOUT V– 4 5 NC V– 4 5 NC S8 PART MARKING N8 PACKAGE, 8-LEAD PDIP S8 PACKAGE, 8-LEAD PLASTIC SO 1360 T T JMAX = 150°C, θJA = 130°C/ W JMAX = 150°C, θJA = 190°C/ W Consult factory for Industrial and Military grade parts.
C, VCM = 0V unless otherwise noted. SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 4) ±15V 0.3 1.0 mV ±5V 0.3 1.0 mV ±2.5V 0.4 1.2 mV IOS Input Offset Current ±2.5V to ±15V 80 250 nA IB Input Bias Current ±2.5V to ±15V 0.3 1.0 µA en Input Noise Voltage f = 10kHz ±2.5V to ±15V 9 nV/√Hz in Input Noise Current f = 10kHz ±2.5V to ±15V 0.9 pA/√Hz RIN Input Resistance VCM = ±12V ±15V 20 50 MΩ Input Resistance Differential ±15V 5 MΩ CIN Input Capacitance ±15V 3 pF Input Voltage Range + ±15V 12.0 13.4 V ±5V 2.5 3.4 V ±2.5V 0.5 1.1 V Input Voltage Range – ±15V –13.2 –12.0 V ±5V –3.2 –2.5 V ±2.5V –0.9 – 0.5 V CMRR Common Mode Rejection Ratio VCM = ±12V ±15V 86 92 dB VCM = ±2.5V ±5V 79 84 dB VCM = ±0.5V ±2.5V 68 74 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 93 105 dB 2
