Datasheet LT1360 (Analog Devices) - 8
Description | 50MHz, 800V/µs Op Amp |
Pages / Page | 16 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Frequency Response vs. Power Supply … |
File Format / Size | PDF / 229 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Frequency Response vs. Power Supply Rejection Ratio. Common Mode Rejection Ratio
LT1360
W U TYPICAL PERFORMANCE CHARACTERISTICS Frequency Response vs Power Supply Rejection Ratio Common Mode Rejection Ratio Capacitive Load vs Frequency vs Frequency
12 100 120 V C = 1000pF +PSRR V VS = ±15V 10 S = ±15V S = ±15V T T A = 25°C T A = 25°C A = 25°C 100 8 AV = –1 80 – PSRR C = 500pF 6 C = 100pF 80 4 60 C = 50pF 2 60 0 40 C = 0 40 –2 VOLTAGE MAGNITUDE (dB) –4 20 20 –6 POWER SUPPLY REJECTION RATIO (dB) COMMON-MODE REJECTION RATIO (dB) –8 0 0 1M 10M 100M 100 1k 10k 100k 1M 10M 100M 1k 10k 100k 1M 10M 100M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1360 G19 1360 G20 1360 G21
Slew Rate vs Supply Voltage Slew Rate vs Temperature Slew Rate vs Input Level
2000 1000 2000 T 1800 TA = 25°C A A = 25°C V = –2 1800 AV = –1 900 V SR + + SR – S = ±15V 1600 RF = RG = 1k SR = ————— 1600 AV = –1 SR+ + SR – 800 2 RF = RG = 1k 1400 SR = ————— 1400 SR + + SR – µs) 2 µs) µs) SR = ————— 1200 700 1200 2 VS = ±15V 1000 600 1000 800 500 800 SLEW RATE (V/ 600 SLEW RATE (V/ SLEW RATE (V/ 600 400 VS = ±5V 400 400 200 300 200 0 200 0 0 5 10 15 – 50 –25 0 25 50 75 100 125 0 2 4 6 8 10 12 14 16 18 20 SUPPLY VOLTAGE (±V) TEMPERATURE (°C) INPUT LEVEL (VP-P) 1360 G22 1360 G23 1360 G24
Total Harmonic Distortion Undistorted Output Swing vs Undistorted Output Swing vs vs Frequency Frequency (
15V) Frequency (
5V)
0.01 30 10 TA = 25°C AV = –1 VO = 3VRMS A 25 V = –1 RL = 500Ω ) 8 P-P P-P 20 AV = 1 6 AV = 1 A 0.001 V = –1 15 4 AV = 1 10 OUTPUT VOLTAGE (V VS = ±15V OUTPUT VOLTAGE (V R 2 V 5 L = 1k S = ±5V TOTAL HARMONIC DISTORTION (%) AV = 1, 1% MAX DISTORTION RL = 1k AV = –1, 2% MAX DISTORTION 2% MAX DISTORTION 0.0001 0 0 10 100 1k 10k 100k 100k 1M 10M 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1360 G25 1360 G26 1360 G27 8
