Datasheet LT1880 (Analog Devices) - 4
DescriptionSOT-23, Rail-to-Rail Output, Picoamp Input Current Precision Op Amp
Pages / Page12 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 233 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1880
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VS = ± 15V; VCM = 0V unless otherwise noted. (Note 5) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
en Input Noise Voltage Density f = 1kHz 13 nV/√Hz in Input Noise Current Density f = 1kHz 0.07 pA/√Hz RIN Input Resistance Differential 380 MΩ Common Mode, VCM = –13.5V to 13.5V 190 GΩ CIN Input Capacitance 3.7 pF VCM Input Voltage Range l –13.5 13.5 V CMRR Common Mode Rejection Ratio –13.5V < VCM < 13.5V l 118 135 dB +PSRR Positive Power Supply Rejection V– = –15V, VCM = 0V; 1.5V < V+ < 18V l 110 135 dB Ratio –PSRR Negative Power Supply Rejection V+ = 15V, VCM = 0V; –1.5V < V– < –18V l 110 135 dB Ratio Minimum Operating Supply Voltage l ±1.2 ±1.35 V AVOL Large Signal Voltage Gain RL = 10k; –13.5V < VOUT < 13.5V 1000 1600 V/mV l 700 V/mV RL = 2k; –13.5V < VOUT < 13.5V 500 1000 V/mV l 300 V/mV VOL Output Voltage Swing Low No Load l 25 65 mV (Referred to VEE) ISINK = 100μA l 35 75 mV ISINK = 1mA l 130 200 mV VOH Output Voltage Swing High No Load l 185 350 mV (Referred to VCC) ISINK = 100μA l 195 370 mV ISINK = 1mA l 270 450 mV IS Supply Current per Amplifi er 1.5 2.3 mA l 1.8 2.8 mA ISC Short-Circuit Current VOUT Short to V– 10 25 mA l 10 25 mA VOUT Short to V+ 10 20 mA l 10 20 mA FPBW Full Power Bandwidth (Note 7) VOUT = 14VP-P 9 kHz GBW Gain Bandwidth Product f = 20kHz 0.8 1.1 MHz THD Total Harmonic Distortion and Noise VO = 25VP-P, AV = –1, f = 100kHz, Rf = 10k, BW = 22kHz 0.00029 % VO = 25VP-P, AV = 1, f = 100kHz, RL = 10k, BW = 22kHz 0.00029 % SR+ Slew Rate Positive AV = –1 0.25 0.4 V/μs l 0.2 V/μs SR– Slew Rate Negative AV = –1 0.25 0.55 V/μs l 0.2 V/μs
Note 1:
Note 4:
The LT1880C and LT1880I are guaranteed functional over the may cause permanent damage to the device. Exposure to any Absolute operating temperature range of –40°C to 85°C. Maximum Rating condition for extended periods may affect device
Note 5:
The LT1880C is guaranteed to meet specifi ed performance from reliability and lifetime. 0°C to 70°C and is designed, characterized and expected to meet specifi ed
Note 2:
The inputs are protected by back-to-back diodes. If the differential performance from –40°C to 85°C but is not tested or QA sampled at these input voltage exceeds 10V, see Application Information, the input current temperatures. The LT1880I is guaranteed to meet specifi ed performance should be limited to less than 10mA. from –40°C to 85°C.
Note 3:
A heat sink may be required to keep the junction temperature
Note 6:
This parameter is not 100% tested. below absolute maximum ratings.
Note 7:
Full power bandwidth is calculated from the slew rate. FPBW = SR/(2πVP) 1880fa 4
