LT1880 SOT-23, Rail-to-Rail Output, Picoamp Input Current Precision Op Amp FEATURESDESCRIPTION n Offset Voltage: 150μV Max The LT®1880 op amp brings high accuracy input perfor- n Input Bias Current: 900pA Max mance and rail-to-rail output swing to the SOT-23 package. n Offset Voltage Drift: 1.2μV/°C Max Input offset voltage is trimmed to less than 150μV and n Rail-to-Rail Output Swing the low drift maintains this accuracy over the operating n Operates with Single or Split Supplies temperature range. Input bias current is an ultralow 900pA n Open-Loop Voltage Gain: 1 Million Min maximum. n 1.2mA Supply Current The amplifi er works on any total power supply voltage n Slew Rate: 0.4V/μs between 2.7V and 36V (fully specifi ed from 5V to ±15V). n Gain Bandwidth: 1.1MHz Output voltage swings to within 55mV of the negative n Low Noise: 13nV/√Hz at 1kHz supply and 250mV of the positive supply, which makes n Low Profi le (1mm) ThinSOT™ Package the amplifi er a good choice for low voltage single supply operation. APPLICATIONS Slew rates of 0.4V/μs with a supply current of 1.2mA give n Thermocouple Amplifi ers superior response and settling time performance in a low n Bridge Transducer Conditioners power precision amplifi er. n Instrumentation Amplifi ers n Battery-Powered Systems The LT1880 is available in a 5-lead SOT-23 package. n Photocurrent Amplifi ers L, LT, LTC, LTM, Linear Technology and the Linear logo are registered trademarks of Linear Technology Corporation. ThinSOT is a trademark of Linear Technology Corporation. All other trademarks are the property of their respective owners. TYPICAL APPLICATIONPrecision Photodiode Amplifi erDistribution of Input Offset Voltage C1 35 39pF 30 R1 25 100k, 1% V + 20 S VL – 15 S1 LT1880 OUT 10 PERCENT OF UNITS (%) + VOUT = 0.1V/μA 5 V – S 1880 TA01 0 –140 –100 –60 –20 20 60 100 140 320μV OUTPUT OFFSET, WORST CASE OVER 0°C TO 70°C INPUT OFFSET VOLTAGE (μV) 60kHz BANDWIDTH 5.8μs RISE TIME, 10% TO 90%, 100mV OUTPUT STEP 1880 TA01b 52μVRMS OUTPUT NOISE, MEASURED ON A 100kHz BW VS = ±1.5V TO ±18V S1: SIEMENS INFINEON BPW21 PHOTODIODE (~580pF) 1880fa 1
