Datasheet LT1352, LT1353 (Analog Devices) - 2
DescriptionDual and Quad 250µA, 3MHz, 200V/µs Operational Amplifiers
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS. (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL …
File Format / SizePDF / 409 Kb
ABSOLUTE MAXIMUM RATINGS. (Note 1). PACKAGE/ORDER INFORMATION. ELECTRICAL CHARACTERISTICS TA = 25
ABSOLUTE MAXIMUM RATINGS (Note 1) PACKAGE/ORDER INFORMATION ELECTRICAL CHARACTERISTICS TA = 25
LT1352/LT1353
W W W U ABSOLUTE MAXIMUM RATINGS (Note 1)
Total Supply Voltage (V + to V –) .. 36V Specified Temperature Range (Note 7) .. – 40°C to 85°C Differential Input Voltage (Transient Only, Note 2) ±10V Maximum Junction Temperature (See Below) Input Voltage .. ±VS Plastic Package ... 150°C Output Short-Circuit Duration (Note 3) ... Indefinite Storage Temperature Range ... – 65°C to 150°C Operating Temperature Range .. – 40°C to 85°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER INFORMATION
TOP VIEW ORDER PART TOP VIEW ORDER PART NUMBER OUT A 1 14 OUT D NUMBER OUT A 1 8 V+ –IN A 2 13 –IN D –IN A 2 7 OUT B A LT1352CN8 A D +IN A 3 12 +IN D LT1353CS +IN A 3 6 –IN B LT1352CS8 B V+ 4 11 V– V– 4 5 +IN B LT1352IN8 +IN B 5 10 +IN C N8 PACKAGE LT1352IS8 B C –IN B 6 9 –IN C 8-LEAD PDIP OUT B 7 8 OUT C S8 PACKAGE S8 PART MARKING 8-LEAD PLASTIC SO S PACKAGE 1352 T 14-LEAD PLASTIC SO JMAX = 150°C, θJA = 130°C/ W (N8) TJMAX = 150°C, θJA = 190°C/ W (S8) 1352I TJMAX = 150°C, θJA = 150°C/ W Consult LTC Marketing for parts specified with wider operating temperature ranges.
C, VCM = 0V unless otherwise noted SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
VOS Input Offset Voltage ±15V 0.2 0.6 mV ±5V 0.2 0.6 mV ±2.5V 0.3 0.8 mV IOS Input Offset Current ±2.5V to ±15V 5 15 nA IB Input Bias Current ±2.5V to ±15V 20 50 nA en Input Noise Voltage f = 10kHz ±2.5V to ±15V 14 nV/√Hz in Input Noise Current f = 10kHz ±2.5V to ±15V 0.5 pA/√Hz RIN Input Resistance VCM = ±12V ±15V 300 600 MΩ Differential ±15V 20 MΩ CIN Input Capacitance ±15V 3 pF Positive Input Voltage Range ±15V 12.0 13.5 V ±5V 2.5 3.5 V ±2.5V 0.5 1.0 V Negative Input Voltage Range ±15V – 13.5 – 12.0 V ±5V – 3.5 – 2.5 V ±2.5V – 1.0 – 0.5 V CMRR Common Mode Rejection Ratio VCM = ±12V ±15V 80 94 dB VCM = ±2.5V ±5V 78 86 dB VCM = ±0.5V ±2.5V 68 77 dB PSRR Power Supply Rejection Ratio VS = ±2.5V to ±15V 90 106 dB 13523fa 2
