Datasheet LT1352, LT1353 (Analog Devices) - 3
Description | Dual and Quad 250µA, 3MHz, 200V/µs Operational Amplifiers |
Pages / Page | 16 / 3 — ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. … |
File Format / Size | PDF / 409 Kb |
ELECTRICAL CHARACTERISTICS TA = 25. C, VCM = 0V unless otherwise noted. SYMBOL. PARAMETER. CONDITIONS. VSUPPLY. MIN. TYP. MAX. UNITS
LT1352/LT1353
C, VCM = 0V unless otherwise noted SYMBOL PARAMETER CONDITIONS VSUPPLY MIN TYP MAX UNITS
AVOL Large-Signal Voltage Gain VOUT = ±12V, RL = 5k ±15V 40 80 V/mV VOUT = ±10V, RL = 2k ±15V 30 60 V/mV VOUT = ±10V, RL = 1k ±15V 20 40 V/mV VOUT = ±2.5V, RL = 5k ±5V 30 60 V/mV VOUT = ±2 .5V, RL = 2k ±5V 25 50 V/mV VOUT = ±2.5V, RL = 1k ±5V 15 30 V/mV VOUT = ±1V, RL = 5k ±2.5V 20 40 V/mV VOUT Output Swing RL = 5k, VIN = ±10mV ±15V 13.5 14.0 ±V RL = 2k, VIN = ±10mV ±15V 13.4 13.8 ±V RL = 1k, VIN = ±10mV ±15V 13.0 13.4 ±V RL = 1k, VIN = ±10mV ±5V 3.5 4.0 ±V RL= 500Ω, VIN = ±10mV ±5V 3.4 3.8 ±V RL = 5k, VIN = ±10mV ±2.5V 1.3 1.7 ±V IOUT Output Current VOUT = ±13V ±15V 13.0 13.4 mA VOUT = ±3.4V ±5V 6.8 7.6 mA ISC Short-Circuit Current VOUT = 0V, VIN = ±3V ±15V 30 45 mA SR Slew Rate AV = – 1, RL = 5k (Note 4) ±15V 120 200 V/µs ±5V 30 50 V/µs Full-Power Bandwidth 10V Peak (Note 5) ±15V 3.2 MHz 3V Peak (Note 5) ±5V 2.6 MHz GBW Gain Bandwidth f = 200kHz, RL = 10k ±15V 2.0 3.0 MHz ± 5V 1.8 2.7 MHz ± 2.5V 2.5 MHz tr, tf Rise Time, Fall Time AV = 1, 10% to 90%, 0.1V ±15V 46 ns ±5V 53 ns Overshoot AV = 1, 0.1V ±15V 13 % ±5V 16 % Propagation Delay 50% VIN to 50% VOUT, 0.1V ±15V 41 ns ±5V 52 ns ts Settling Time 10V Step, 0.1%, AV = – 1 ±15V 700 ns 10V Step, 0.01%, AV = – 1 ±15V 1250 ns 5V Step, 0.1%, AV = – 1 ±5V 950 ns 5V Step, 0.01%, AV = – 1 ±5V 1400 ns RO Output Resistance AV = 1, f = 20kHz ±15V 1.5 Ω Channel Separation VOUT = ±10V, RL = 2k ±15V 101 120 dB IS Supply Current Each Amplifier ±15V 250 320 µA Each Amplifier ±5V 230 300 µA
0
C
TA
70
VOS Input Offset Voltage ±15V 0.8 mV ±5V 0.8 mV ±2.5V 1.0 mV Input VOS Drift (Note 6) ±2.5V to ±15V 3 8 µV/°C IOS Input Offset Current ±2.5V to ±15V 20 nA IB Input Bias Current ±2.5V to ±15V 75 nA 13523fa 3
