Datasheet LT1113 (Analog Devices) - 5
DescriptionDual Low Noise, Precision, JFET Input Op Amps
Pages / Page18 / 5 — elecTrical characTerisTics The. denotes specifications which apply over …
File Format / SizePDF / 721 Kb
elecTrical characTerisTics The. denotes specifications which apply over the temperature range
elecTrical characTerisTics The denotes specifications which apply over the temperature range
LT1113
denotes specifications which apply over the temperature range –40°C ≤ TA ≤ 85°C. VS = ±15V, VCM = 0V, unless otherwise noted. (Note 10) LT1113AC LT1113C SYMBOL PARAMETER CONDITIONS (Note 4) MIN TYP MAX MIN TYP MAX UNITS
IS Supply Current per Amplifier l 5.30 6.35 5.30 6.55 mA VS = ±5V l 5.25 6.30 5.25 6.50 mA ∆VOS Offset Voltage Match l 1.0 4.4 1.0 5.1 mV ∆I + B Noninverting Bias Current Match l 50 600 55 900 pA ∆CMRR Common Mode Rejection Match (Note 11) l 76 93 73 93 dB ∆PSRR Power Supply Rejection Match (Note 11) l 77 92 75 92 dB
The
denotes specifications which apply over the temperature range –55°C ≤ TA ≤ 125°C. VS = ±15V, VCM = 0V, unless otherwise noted. (Note 12) LT1113AM LT1113M SYMBOL PARAMETER CONDITIONS (Note 4) MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage l 0.8 2.7 0.9 3.3 mV VS = ±5V l 0.8 2.8 0.9 3.4 mV ∆VOS Average Input Offset (Note 8) l 5 12 8 15 µV/°C ∆Temp Voltage Drift IOS Input Offset Current l 0.8 15 1.0 25 nA IB Input Bias Current l 25 50 27 70 nA VCM Input Voltage Range l 12.6 13.0 12.6 13.0 V l –10.0 –10.4 –10.0 –10.4 V CMRR Common Mode Rejection Ratio VCM = –10V to 12.6V l 79 95 77 92 dB PSRR Power Supply Rejection Ratio VS = ±4.5V to ±20V l 80 97 78 95 dB AVOL Large-Signal Voltage Gain VO = ±12V, RL = 10k l 800 2700 700 2500 V/mV VO = ±10V, RL = 1k l 400 1500 300 1000 V/mV VOUT Output Voltage Swing RL = 10k l ±13.0 ±12.5 ±12.5 ±12.5 V RL = 1k l ±11.5 ±12.0 ±11.0 ±12.0 V SR Slew Rate RL ≥ 2k (Note 9) l 1.9 3.3 1.6 3.3 V/µs GBW Gain Bandwidth Product fO = 100kHz l 2.2 3.4 2.2 3.4 MHz IS Supply Current Per Amplifier l 5.30 6.35 5.30 6.55 mA VS = ±5V l 5.25 6.30 5.25 6.50 mA ∆VOS Offset Voltage Match l 1.0 5.0 1.0 5.5 mV ∆I + B Noninverting Bias Current Match l 1.8 12 2.0 20 nA ∆CMRR Common Mode Rejection Match (Note 11) l 75 92 73 92 dB ∆PSRR Power Supply Rejection Match (Note 11) l 76 91 74 91 dB
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings factory. The LT1113M is guaranteed to meet specified performance from may cause permanent damage to the device. Exposure to any Absolute –55°C to 125°C. Maximum Rating condition for extended periods may affect device
Note 4:
Typical parameters are defined as the 60% yield of parameter reliability and lifetime. distributions of individual amplifiers, i.e., out of 100 LT1113s (200 op
Note 2:
The LT1113C is guaranteed functional over the Operating amps) typically 120 op amps will be better than the indicated specification. Temperature Range of –40°C to 85°C. The LT1113M is guaranteed
Note 5:
Warmed-up IB and IOS readings are extrapolated to a chip temperature functional over the Operating Temperature Range of –55°C to 125°C. of 50°C from 25°C measurements and 50°C characterization data.
Note 3:
The LT1113C is guaranteed to meet specified performance from
Note 6:
Current noise is calculated from the formula: 0°C to 70°C. The LT1113C is designed, characterized and expected to i meet specified performance from –40°C to 85°C but is not tested or QA n = (2qIB)1/2 sampled at these temperatures. For guaranteed I grade parts, consult the where q = 1.6 • 10–19 coulomb. The noise of source resistors up to 200M swamps the contribution of current noise. 1113fc For more information www.linear.com/LT1113 5
