Datasheet LT1113 (Analog Devices) - 7
DescriptionDual Low Noise, Precision, JFET Input Op Amps
Pages / Page18 / 7 — Typical perForMance characTerisTics. Common Mode Limit vs. Common Mode …
File Format / SizePDF / 721 Kb
Typical perForMance characTerisTics. Common Mode Limit vs. Common Mode Rejection Ratio vs. Power Supply Rejection Ratio
Typical perForMance characTerisTics Common Mode Limit vs Common Mode Rejection Ratio vs Power Supply Rejection Ratio
LT1113
Typical perForMance characTerisTics Common Mode Limit vs Common Mode Rejection Ratio vs Power Supply Rejection Ratio Temperature Frequency vs Frequency
V+ –0 120 120 –0.5 TA = 25°C TA = 25°C 100 VS = ±15V –1.0 V+ = 5V TO 20V 100 –1.5 80 80 –2.0 +PSRR 60 60 –PSRR 4.0 3.5 V– = –5V TO –20V 40 40 COMMON MODE LIMIT (V) REFERRED TO POWER SUPPLY 3.0 20 20 2.5 COMMON-MODE REJECTION RATIO (dB) POWER SUPPLY REJECTION RATIO (dB) V– +2.0 0 0 –60 –20 20 60 100 140 1k 10k 100k 1M 10M 10 100 1k 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz) FREQUENCY (Hz) 1113 G08 1113 G07 1113 G09
Voltage Gain vs Gain and Phase Shift vs Voltage Gain vs Frequency Chip Temperature Frequency
180 10 50 60 TA = 25°C VS = ±15V T 9 A = 25°C VS = ±15V VO = ±10V, RL = 1k VS = ±15V 140 40 8 VO = ±12V, RL = 10k C 80 L = 10pF PHASE SHIFT (DEG) 7 30 100 100 6 RL =10k 5 20 120 60 PHASE 4 VOLTAGE GAIN (dB) RL = 1k 3 VOLTAGE GAIN (dB) 10 140 VOLTAGE GAIN (V/µV) GAIN 20 2 0 160 1 –20 0 –10 180 0.01 1 100 10k 1M 100M –75 –50 –25 0 25 50 75 100 125 0.1 1 10 100 FREQUENCY (Hz) CHIP TEMPERATURE (°C) FREQUENCY (MHz) 1113 G10 1113 G12 1113 G11
Small-Signal Transient Response Large-Signal Transient Response Supply Current vs Supply Voltage
6 25°C –55°C 5V/DIV 20mV/DIV 5 125°C 1µs/DIV 2µs/DIV SUPPLY CURRENT PER AMPLIFIER (mA) AV = 1 AV = 1 CL = 10pF CL = 10pF 4 V 1113 G13 V 1113 G14 0 S = ±15V, ±5V S = ±15V ±5 ±10 ±15 ±20 SUPPLY VOLTAGE (V) 1113 G15 1113fc For more information www.linear.com/LT1113 7
