LT1213/LT1214 ELECTRICAL CHCARA TERISTICSNote 1: Absolute Maximum Ratings are those values beyond which the life Note 5: Guaranteed by correlation to 3.3V and ±15V tests. of a device may be impaired. Note 6: The LT1213/LT1214 are designed, characterized and expected to Note 2: A heat sink may be required to keep the junction temperature meet these extended temperature limits, but are not tested at –40°C and below absolute maximum when the output is shorted indefinitely. 85°C. Guaranteed I grade parts are available. Consult factory. Note 3: TJ is calculated from the ambient temperature TA and power Note 7: Slew rate is measured between ±8.5V on an output swing of ±10V dissipation PD according to the following formulas: on ±15V supplies. LT1213MJ8, LT1213AMJ8: TJ = TA + (PD × 100°C/W) Note 8: Most LT1213/LT1214 electrical characteristics change very little LT1213CN8, LT1213ACN8: TJ = TA + (PD × 100°C/W) with supply voltage. See the 5V tables for characteristics not listed in the LT1213CS8: TJ = TA + (PD × 150°C/W) 3.3V table. LT1214CN: TJ = TA + (PD × 70°C/W) Note 9: Guaranteed by correlation to 5V and ±15V tests. LT1214CS: TJ = TA + (PD × 100°C/W) Note 10: Guaranteed by correlation to 3.3V tests. Note 4: This parameter is not 100% tested. WUTYPICAL PERFOR A CE CHCARA TERISTICSDistribution of Offset Voltage DriftDistribution of Input Offset Voltagewith TemperatureDistribution of Input Offset Voltage 70 50 70 V LT1213 J8 PACKAGE V LT1213 J8 PACKAGE S = 5V V LT1213 J8 PACKAGE S = 5V S = ±15V LT1213 N8 PACKAGE LT1213 N8 PACKAGE 60 60 LT1213 N8 PACKAGE 40 50 50 30 40 40 30 30 20 20 20 PERCENT OF UNITS (%) PERCENT OF UNITS (%) PERCENT OF UNITS (%) 10 10 10 0 0 0 –350 –250 –150 –50 50 150 250 350 –3 –2 –1 0 1 2 3 –700 –500 –300 –100 100 300 500 700 INPUT OFFSET VOLTAGE (µV) OFFSET VOLTAGE DRIFT WITH TEMPERATURE (µV/°C) INPUT OFFSET VOLTAGE (µV) 1213/14 G01 1213/14 G03 1213/14 G02 Distribution of Offset Voltage DriftDistribution of Input Offset Voltagewith TemperatureDistribution of Input Offset Voltage 70 50 70 V LT1213 S8 PACKAGE V LT1213 S8 PACKAGE S = 5V S = 5V V LT1213 S8 PACKAGE S = ±15V 60 LT1214 N PACKAGE LT1214 N PACKAGE 60 LT1214 N PACKAGE LT1214 S PACKAGE 40 LT1214 S PACKAGE LT1214 S PACKAGE 50 50 30 40 40 30 30 20 20 PERCENT OF UNITS (%) PERCENT OF UNITS (%) 20 PERCENT OF UNITS (%) 10 10 10 0 0 0 –350 –250 –150 –50 50 150 250 350 –6 –4 –2 0 2 4 6 –700 –500 –300 –100 100 300 500 700 INPUT OFFSET VOLTAGE (µV) OFFSET VOLTAGE DRIFT WITH TEMPERATURE (µV/°C) INPUT OFFSET VOLTAGE (µV) 1213/14 G04 1213/14 G05 1213/14 G06 8
