Datasheet LT1213, LT1214 (Analog Devices) - 9
Description28MHz, 12V/µs, Single Supply Quad Precision Op Amps
Pages / Page20 / 9 — TYPICAL PERFOR A CE CH. ARA TERISTICS. Voltage Gain, Phase vs. …
File Format / SizePDF / 401 Kb
TYPICAL PERFOR A CE CH. ARA TERISTICS. Voltage Gain, Phase vs. Gain-Bandwidth Product,. Voltage Gain vs Frequency. Frequency
TYPICAL PERFOR A CE CH ARA TERISTICS Voltage Gain, Phase vs Gain-Bandwidth Product, Voltage Gain vs Frequency Frequency
LT1213/LT1214
W U TYPICAL PERFOR A CE CH C ARA TERISTICS Voltage Gain, Phase vs Gain-Bandwidth Product, Voltage Gain vs Frequency Frequency Phase Margin vs Supply Voltage
140 60 100 32 PHASE CL = 20pF 30 120 R 80 L = 2k T 28 A = –55°C TA = 25°C 100 40 VS = ±15V 60 PHASE SHIFT (DEG) 26 PHASE MARGIN (DEG) GAIN 24 80 40 TA = 125°C 22 VS = 5V 60 20 20 20 60 50 T 40 0 A = 25°C, 125°C 40 VOLTAGE GAIN (dB) VS = ±15V VOLTAGE GAIN (dB) TA = –55°C 20 0 VS = 5V –20 30 C 20 0 L = 20pF VS = ±15V –40 GAIN-BANDWIDTH PRODUCT (MHz) R V L = 2k 10 S = 5V –20 –20 –60 0 1 10 100 1k 10k 100k 1M 10M 100M 100k 1M 10M 100M 1 3 5 7 10 20 30 40 FREQUENCY (Hz) FREQUENCY (Hz) TOTAL SUPPLY VOLTAGE (V) 1213/14 G07 1213/14 G08 1213/14 G09
Slew Rate vs Temperature Slew Rate vs Supply Voltage Capacitive Load Handling
18 16 80 T A A = 25°C V = –2 T V A = 125°C S = 5V 16 A R V = –2 L = 10k 70 14 RL = 10k VS = ±15V 14 60 µs) µs) 12 12 T 50 A = 25°C 10 10 40 AV = 1 8 VS = 5V 30 T SLEW RATE (V/ SLEW RATE (V/ 8 A = –55°C OVERSHOOT (%) 6 20 AV = 5 6 4 10 AV = 10 2 4 0 –50 –25 0 25 50 75 100 125 0 4 8 12 16 20 24 28 32 36 10 100 1000 TEMPERATURE (°C) TOTAL SUPPLY VOLTAGE (V) CAPACITIVE LOAD (pF) 1213/14 G10 1213/14 G11 1213/14 G12
Undistorted Output Swing Undistorted Output Swing Total Harmonic Distortion and vs Frequency, VS = 5V vs Frequency, VS =
15V Noise vs Frequency
5 30 0.1 V V S = 5V S = 5V AV = –1 V 25 O = 3VP-P 4 RL = 1k ) A P-P V = 1 P-P 20 0.01 3 A 15 V = 10 2 10 0.001 AV = 1 OUTPUT SWING (V OUTPUT SWING (V 1 5 VS = ±15V 0 0 TOTAL HARMONIC DISTORTION AND NOISE (%) 0.0001 100 1k 10k 100k 1M 100 1k 10k 100k 1M 10 100 1k 10k 100k FREQUENCY (Hz) FREQUENCY (Hz) FREQUENCY (Hz) 1213/14 G13 1213/14 G14 1213/14 G15 9
