Datasheet LT1211, LT1212 (Analog Devices) - 5
Description | 14MHz, 7V/µs, Single Supply Dual and Quad Precision Op Amps |
Pages / Page | 20 / 5 — 5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55. … |
File Format / Size | PDF / 394 Kb |
5V ELECTRICAL CH. ARA TERISTICS. VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55. 125. C, unless otherwise noted. LT1211AM. LT1211M
LT1211/LT1212
5V ELECTRICAL CH C ARA TERISTICS VS = 5V, VCM = 0.5V, VOUT = 0.5V, – 55
C
TA
125
C, unless otherwise noted. LT1211AM LT1211M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 140 250 200 500 µV ∆VOS Input Offset Voltage Drift 0.7 1.5 1 3 µV/°C ∆T (Note 4) IOS Input Offset Current 15 40 25 75 nA IB Input Bias Current 75 130 85 160 nA Input Voltage Range 3.1 3.2 3.1 3.2 V 0.4 0.2 0.4 0.2 V CMRR Common Mode Rejection Ratio VCM = 0.4V to 3.1V 87 104 81 101 dB PSRR Power Supply Rejection Ratio VS = 2.5V to 12.5V 87 113 84 109 dB AVOL Large-Signal Voltage Gain VO = 0.05V to 3.7V, RL = 500Ω 100 250 100 250 V/mV Maximum Output Voltage Swing Output High, No Load 4.10 4.20 4.10 4.20 V (Note 5) Output High, ISOURCE = 1mA 3.95 4.10 3.95 4.10 V Output High, ISOURCE = 10mA 3.70 3.90 3.70 3.90 V Output Low, No Load 0.007 0.010 0.007 0.010 mV Output Low, ISINK = 1mA 0.060 0.085 0.060 0.085 mV Output Low, ISINK = 10mA 0.350 0.500 0.350 0.500 mV IS Supply Current per Amplifier 0.5 1.7 2.5 0.5 1.7 2.5 mA
+15V ELECTRICAL CH C ARA TERISTICS – VS =
15V, VCM = 0V, VOUT = 0V, TA = 25
C, unless otherwise noted. LT1211AC LT1211C/LT1211M LT1211AM LT1212C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 125 400 150 550 µV IOS Input Offset Current 5 20 5 30 nA IB Input Bias Current 45 95 50 120 nA Input Voltage Range 13.5 13.8 13.5 13.8 V –15.0 – 15.3 –15.0 – 15.3 V CMRR Common Mode Rejection Ratio VCM = –15V to 13.5V 90 105 86 102 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V 90 113 87 110 dB AVOL Large-Signal Voltage Gain VO = 0V to ±10V, RL = 2k 1200 5000 1200 5000 V/mV Maximum Output Voltage Swing Output High, ISOURCE = 15mA 13.8 14.0 13.8 14.0 V Output Low, ISINK = 15mA –14.4 –14.6 –14.4 –14.6 V IO Maximum Output Current (Note 10) ±20 ±50 ±20 ±50 mA SR Slew Rate AV = – 2 (Note 7) 5 7 5 7 V/µs GBW Gain-Bandwidth Product f = 100kHz 8 14 8 14 MHz IS Supply Current per Amplifier 0.9 1.8 2.5 0.9 1.8 2.5 mA Channel Separation VO = ±10V, RL = 2k 128 140 128 140 dB Minimum Supply Voltage Equal Split Supplies ±1.2 ±2.0 ±1.2 ±2.0 V Full Power Bandwidth AV = 1, VO = 20VP-P 60 60 kHz Settling Time 0.01%, AV = 1, ∆VO = 10V 2.2 2.2 µs 5
