Datasheet LT1211, LT1212 (Analog Devices) - 6
Description14MHz, 7V/µs, Single Supply Dual and Quad Precision Op Amps
Pages / Page20 / 6 — –15V ELECTRICAL CH. ARA TERISTICS. VS =. 15V, VCM = 0V, VOUT = 0V, 0. C, …
File Format / SizePDF / 394 Kb
–15V ELECTRICAL CH. ARA TERISTICS. VS =. 15V, VCM = 0V, VOUT = 0V, 0. C, unless otherwise noted. LT1211AC. LT1211C/LT1212C
–15V ELECTRICAL CH ARA TERISTICS VS = 15V, VCM = 0V, VOUT = 0V, 0 C, unless otherwise noted LT1211AC LT1211C/LT1212C
LT1211/LT1212
+ –15V ELECTRICAL CH C ARA TERISTICS VS =
C
TA
70
C, unless otherwise noted. LT1211AC LT1211C/LT1212C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 150 425 200 650 µV ∆VOS Input Offset Voltage Drift 8-Pin DIP Package 0.7 1.5 1 3 µV/°C ∆T (Note 4) 14-Pin DIP, SOIC Package 2 6 µV/°C IOS Input Offset Current 10 20 10 35 nA IB Input Bias Current 55 100 60 125 nA Input Voltage Range 13.4 13.5 13.4 13.5 V –14.9 –15.1 –14.9 –15.1 V CMRR Common Mode Rejection Ratio VCM = –14.9V to 13.4V 89 104 85 101 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V 89 112 86 108 dB AVOL Large-Signal Voltage Gain VO = 0V to ±10V, RL = 2k 1000 3500 1000 3500 V/mV Maximum Output Voltage Swing Output High, ISOURCE = 10mA 13.8 14.0 13.8 14.0 V Output Low, ISINK = 10mA – 14.5 – 14.7 – 14.5 – 14.7 V IS Supply Current per Amplifier 0.8 2.1 2.9 0.8 2.1 2.9 mA
VS =
15V, VCM = 0V, VOUT = 0V, – 40
C
TA
85
C, unless otherwise noted. (Note 6) LT1211C/LT1212C LT1211AC LT1211I/LT1212I SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 175 450 250 700 µV ∆VOS Input Offset Voltage Drift 8-Pin DIP Package 0.7 1.5 1 3 µV/°C ∆T (Note 4) 14-Pin DIP, SOIC Package 2 6 µV/°C IOS Input Offset Current 10 25 10 40 nA IB Input Bias Current 55 100 60 130 nA Input Voltage Range 13.1 13.2 13.1 13.2 V –14.8 –15.0 –14.8 –15.0 V CMRR Common Mode Rejection Ratio VCM = – 14.8V to 13.1V 88 103 84 100 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V 88 111 85 107 dB AVOL Large-Signal Voltage Gain VO = 0V to ±10V, RL = 2k 1000 3000 1000 3000 V/mV Maximum Output Voltage Swing Output High, ISOURCE = 10mA 13.7 13.9 13.7 13.9 V Output Low, ISINK = 10mA – 14.5 – 14.7 – 14.5 – 14.7 V IS Supply Current per Amplifier 0.7 2.2 3.0 0.7 2.2 3.0 mA
VS =
15V, VCM = 0V, VOUT = 0V, – 55
C
TA
125
C, unless otherwise noted. LT1211AM LT1211M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 200 500 300 800 µV ∆VOS Input Offset Voltage Drift 0.7 1.5 1 3 µV/°C ∆T (Note 4) IOS Input Offset Current 10 40 10 60 nA IB Input Bias Current 55 110 60 140 nA Input Voltage Range 13.1 13.2 13.1 13.2 V –14.6 –14.8 –14.6 –14.8 V CMRR Common Mode Rejection Ratio VCM = – 14.6V to 13.1V 87 103 81 100 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±15V 87 111 84 107 dB AVOL Large-Signal Voltage Gain VO = 0V to ±10V, RL = 2k 800 1500 800 1500 V/mV Maximum Output Voltage Swing Output High, ISOURCE = 10mA 13.6 13.8 13.6 13.8 V Output Low, ISINK = 10mA –14.3 –14.5 –14.3 –14.5 V IS Supply Current per Amplifier 0.5 2.3 3.4 0.5 2.3 3.4 mA 6
