Datasheet LT1077 (Analog Devices) - 2
DescriptionMicropower, Single Supply, Precision Op Amp
Pages / Page16 / 2 — ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. …
File Format / SizePDF / 309 Kb
ABSOLUTE AXI U RATI GS (Note 1). (OBSOLETE). PACKAGE/ORDER I FOR ATIO. OBSOLETE PACKAGE
ABSOLUTE AXI U RATI GS (Note 1) (OBSOLETE) PACKAGE/ORDER I FOR ATIO OBSOLETE PACKAGE
LT1077
W W W U ABSOLUTE AXI U RATI GS (Note 1)
Supply Voltage .. ±22V Operating Temperature Range Differential Input Voltage ... ±30V LT1077AM/LT1077M
(OBSOLETE)
.. – 55°C to 125°C Input Voltage ... Equal to Positive Supply Voltage LT1077AI/LT1077I .. – 40°C to 85°C Input Voltage .. 5V Below Negative Supply Voltage LT1077AC/LT1077C/LT1077S8 ... 0°C to 70°C Output Short-Circuit Duration .. Indefinite Storage Temperature Range ... – 65°C to 150°C Lead Temperature (Soldering, 10 sec).. 300°C
U W U PACKAGE/ORDER I FOR ATIO
TOP VIEW VOS TRIM TOP VIEW TOP VIEW 8 V 1 7 V+ OS TRIM V 1 OS TRIM 8 VOS TRIM V 1 8 V OS TRIM OS TRIM A B –IN 2 6 OUT – + + – –IN 2 7 V+ –IN 2 7 V+ +IN 3 6 OUT +IN 3 6 OUT +IN 3 5 NC 4 V– 4 5 NC V– 4 5 NC V– H PACKAGE J8 PACKAGE N8 PACKAGE S8 PACKAGE 8-LEAD TO-5 METAL CAN 8-LEAD CERDIP 8-LEAD PDIP 8-LEAD PLASTIC SO TJMAX = 150°C, θJA = 150°C/W, θJC = 45°C/W TJMAX = 150°C, θJA = 100°C/W TJMAX = 100°C, θJA = 130°C/W TJMAX = 150°C, θJA = 190°C/W ORDER PART NUMBER ORDER PART NUMBER ORDER PART NUMBER S8 PART MARKING LT1077AMH LT1077AMJ8 LT1077S8 1077 LT1077MH LT1077MJ8 LT1077IS8 1077I LT1077ACH LT1077ACJ8 LT1077AIN8 LT1077CH LT1077CJ8 LT1077IN8 LT1077ACN8
OBSOLETE PACKAGE
Consider the N8 or S8 Package for Alternate Source LT1077CN8 LT1077 • POI01 Consult LTC Marketing for parts specified with wider operating temperature ranges.
ELECTRICAL CHARACTERISTICS VS = 5V, 0V, VCM = 0.1V, VO = 1.4V, TA = 25
C unless noted. LT1077AM/AI/AC LT1077M/I/C/S8 SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage 9 40 10 60 µV LT1077S8 12 150 µV ∆VOS Long Term Input Offset 0.4 0.4 µV/Mo ∆Time Voltage Stability IOS Input Offset Current 0.06 0.35 0.06 0.45 nA IB Input Bias Current 7 9 7 11 nA en Input Noise Voltage 0.1Hz to 10Hz (Note3) 0.5 1.1 0.5 µVP-P Input Noise Voltage Density fO = 10Hz (Note 3) 28 43 28 nV/√Hz fO = 1000Hz (Note3) 27 35 27 nV/√Hz in Input Noise Current 0.1Hz to 10Hz (Note3) 2.5 4.5 2.5 pAP-P 1077fa 2
