Datasheet LT1078, LT1079 (Analog Devices) - 8
DescriptionMicropower, Dual and Quad, Single Supply, Precision Op Amps
Pages / Page20 / 8 — TYPICAL PERFORMANCE CHARACTERISTICS. Voltage Gain vs Frequency. Gain, …
File Format / SizePDF / 618 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Voltage Gain vs Frequency. Gain, Phase vs Frequency. Capacitive Load Handling
TYPICAL PERFORMANCE CHARACTERISTICS Voltage Gain vs Frequency Gain, Phase vs Frequency Capacitive Load Handling
LT1078/LT1079
W U TYPICAL PERFORMANCE CHARACTERISTICS Voltage Gain vs Frequency Gain, Phase vs Frequency Capacitive Load Handling
140 120 30 T PHASE T A = 25°C A = 25°C 120 MARGIN V 100 S = 5V, 0V 100 66° 100 VS = ±15V 20 120 PHASE SHIFT (DEG) ±15V 80 5V, 0V 80 AV = 1 140 VS = 5V, 0V PHASE GAIN 60 10 MARGIN 160 60 54° AV = 5 40 5V, 0V 180 OVERSHOOT (%) 40 VOLTAGE GAIN (dB) A VOLTAGE GAIN (dB) V = 10 20 0 ±15V 200 20 0 TA = 25°C CL = 20pF –20 –10 0 0.01 0.1 1 10 100 1k 10k 100k 1M 10 10 100 1000 10000 30 100 300 1000 FREQUENCY (Hz) CAPACITIVE LOAD (pF) FREQUENCY (kHz) LT1078/79 • TPC12 LT1078/79 • TPC10 LTC1078/79 TPC11
Slew Rate, Gain Bandwidth Product and Phase Margin vs Large-Signal Transient Response Large-Signal Transient Response Temperature VS = 5V, 0V VS =
15V
0.12 μs) SLEW = ±15V 0.10 SLEW = 5V, 0V 0.08 PHASE MARGIN (DEG) 0.06 80 SLEW RATE (V/ 0.04 φ 70 M = ±15V 1V/DIV 0V 5V/DIV 60 φM = 5V, 0V 240 50 0V 220 GBW = ±15V 40 200 AV = 1, NO LOAD 50μs/DIV AV = 1 100μs/DIV PRODUCT (kHz) 180 GBW = 5V, 0V f INPUT PULSE 0V TO 3.8V NO LOAD GAIN BANDWIDTH O = 20kHz 160 LT1078/79 • TPC27 LT1078/79 • TPC28 –50 –25 0 25 50 75 100 125 TEMPERATURE (°C) LT1078/79 • TPC13
Minimum Supply Voltage Warm-Up Drift Voltage Gain vs Load Resistance
100 0.8 10M V– = 0V V T S = ±15V A = 25°C 25 –0.1V ≤ V V °C CM ≤ 0.4V V S = 5V, 0V 0.7 S = ±15V 0 μV) WARM UP DRIFT μV) AT V 125 125°C °C –55°C 0.6 S = 5V, 0V IS IMMEASURABLY LOW –100 0.5 –200 70°C 0.4 1M –55°C 0°C 25°C 25°C –55°C 0.3 –300 NONFUNCTIONAL LT1079 VOLTAGE GAIN (V/V) 125°C 0.2 INPUT OFFSET VOLTAGE ( –400 CHANGE IN OFFSET VOLTAGE ( LT1078 0.1 –500 0 100k 0 1 2 3 0 1 2 3 100 1k 10k 100k 1M POSITIVE SUPPLY VOLTAGE (V) TIME AFTER POWER-ON (MINUTES) LOAD RESISTANCE TO GROUND (Ω) LT1078/79 • TPC18 LT1078/79 • TPC16 LT1078/79 • TPC17 10789fe 8
