Datasheet LT1006 (Analog Devices) - 5
DescriptionPrecision, Single Supply Op Amp
Pages / Page16 / 5 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 304 Kb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the full operating. temperature range. VS =
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the full operating temperature range VS =
LT1006
denotes the specifications which apply over the full operating temperature range. VS =
15V, –55
C
TA
125
C, unless otherwise noted. LT1006AM LT1006M SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage ● 80 320 110 460 µV ∆VOS Input Offset Voltage Drift ● 0.5 2.2 0.6 2.8 µV/°C ∆Temp IOS Input Offset Current ● 0.2 2.0 0.3 3.0 nA IB Input Bias Current ● 9 18 11 27 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 2k ● 0.5 1.5 0.25 1.0 V/µV CMRR Common Mode Rejection Ratio VCM = +13V, –14.9V ● 97 114 94 113 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V, VO = 0V ● 100 117 97 116 dB Maximum Output Voltage Swing RL = 2k ● ±12 ±13.8 ±11.5 ±13.8 V IS Supply Current ● 400 650 400 750 µA
The
15V, 0
C
TA
70
C, unless otherwise noted. LT1006AC LT1006C SYMBOL PARAMETER CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
VOS Input Offset Voltage J8/H Package ● 50 200 75 300 µV N8 Package ● 80 330 µV S8 Package ● 150 730 µV ∆VOS Input Offset Voltage Drift J8/H Package ● 0.5 2.2 0.6 2.8 µV/°C ∆Temp N8 Package ● 0.7 3.5 µV/°C S8 Package ● 1.0 4.5 µV/°C IOS Input Offset Current ● 0.15 1 0.25 2 nA IB Input Bias Current ● 8 15 10 23 nA AVOL Large-Signal Voltage Gain VO = ±10V, RL = 2k ● 1 3 0.7 2.5 V/µV CMRR Common Mode Rejection Ratio VCM = 13V, –15V ● 98 116 94 114 dB PSRR Power Supply Rejection Ratio VS = ±2V to ±18V, VO = 0V ● 101 120 97 118 dB Maximum Output Voltage Swing RL = 2k ● ±12.5 ±13.9 ±11.5 ±13.8 V IS Supply Current ● 370 600 380 660 µA
Note 1:
Note 4:
Optional offset nulling is accomplished with a potentiometer of a device may be impaired. connected between the trim terminals and the wiper to V–. A 10k pot
Note 2:
This parameter is guaranteed by design and is not tested. (providing a null range of ±6mV) is recommended for minimum drift of
Note 3:
Regular operation does not require an external resistor. In order nulled offset voltage with temperature. For increased trim resolution and to program the supply current for low power or high speed operation, accuracy, two fixed resistors can be used in conjunction with a smaller connect an external resistor from Pin 8 to Pin 7 or from Pin 8 to Pin 4, potentiometer. For example, two 4.7k resistors tied to Pins 1 and 5, with a respectively. Supply current specifications (for R 500Ω pot in the middle, will have a null range of ±150µV. SET = 180k) do not include current in RSET. 1006fa 5
