Datasheet LT1006 (Analog Devices)
DescriptionPrecision, Single Supply Op Amp
Pages / Page16 / 1 — FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. LT1006 Single …
File Format / SizePDF / 304 Kb
FEATURES. DESCRIPTIO. APPLICATIO S. TYPICAL APPLICATIO. LT1006 Single Supply, Micropower Sample and Hold
Datasheet LT1006 Analog Devices
LT1006 Precision, Single Supply Op Amp
U FEATURES DESCRIPTIO
■ Single Supply Operation The LT®1006 is the first precision single supply operational Input Voltage Range Extends to Ground amplifier. Its design has been optimized for single supply Output Swings to Ground while Sinking Current operation with a full set of specifications at 5V. ■ Guaranteed Offset Voltage: 50µV Max Specifications at ±15V are also provided. ■ Guaranteed Low Drift: 1.3µV/°C Max The LT1006 has a low offset voltage of 20µV, drift of ■ Guaranteed Offset Current: 0.5nA Max 0.2µV/°C, offset current of 120pA, gain of 2.5 million, ■ Guaranteed High Gain common mode rejection of 114dB and power supply 5mA Load Current: 1.5 Million Min rejection of 126dB. 17mA Load Current: 0.8 Million Min ■ Guaranteed Low Supply Current: 520 Although supply current is only 340 µA Max µA, a novel output ■ Supply Current can be Reduced by a Factor of 4 stage can source or sink in excess of 20mA while retaining ■ Low Voltage Noise, 0.1Hz to 10Hz: 0.55 high voltage gain. Common mode input range includes µVP-P Low Current Noise— ground to accommodate low ground-referenced inputs Better than OP-07: 0.07pA/ from strain gauges or thermocouples, and output can √Hz at 10Hz ■ High Input Impedance: 250M swing to within a few millivolts of ground. If a higher Ω Min ■ Minimum Supply Voltage: 2.7V Min slew rate (in excess of 1V/µs) or micropower operation (supply current down to 90
U
µA) is required, the operating
APPLICATIO S
currents can be modified by connecting an external optional resistor to Pin 8. ■ Low Power Sample-and-Hold Circuits For similar single supply precision dual and quad op amps, ■ Battery-Powered Precision Instrumentation please see the LT1013/LT1014 data sheet. For micropower Strain Gauge Signal Conditioners dual and quad op amps, please see the LT1078/LT1079 Thermocouple Amplifiers data sheet. ■ 4mA to 20mA Current Loop Transmitters ■ Active Filters , LTC and LT are registered trademarks of Linear Technology Corporation.
U TYPICAL APPLICATIO LT1006 Single Supply, Micropower Sample and Hold Distribution of Input Offset Voltage
9V 20 VS = 5V, 0V 18 TA = 25°C 360k 360k 350 LT1006s TESTED 1/4 CD4066 1/4 CD4066 16 FROM TWO RUNS 14 J AND N PACKAGES 390Ω S3 S4 390Ω 12 10 8 UNITS (%) 8 1/2 CD4066 2 7 – 7 2 A2 6 6 – 8 OUTPUT S1 LT1006 A1 6 3 4 LT1006 + 4 3 INPUT 2 S2 + 0.01µF 0V TO 5V 4 0 ACQUISITION TIME 20µs –80 –40 0 40 80 HOLD SETTLING TIME 10µs INPUT OFFSET VOLTAGE ( 1/2 CD4066 µV) S-H OFFSET 1mV SAMPLE-HOLD COMMAND HOLD SUPPLY CURRENT 250µA LT1006 • G01 HIGH = SAMPLE SAMPLE SUPPLY CURRENT 5.0mA LT1006 • TA01 LOW = HOLD 1kHz SAMPLE RATE CURRENT 800µA 1006fa 1
