Datasheet ADP5303 (Analog Devices) - 4
Description50 mA/500 mA, Ultralow Power Step-Down Regulator with Battery Voltage Monitor
Pages / Page21 / 4 — ADP5303. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. …
RevisionB
File Format / SizePDF / 768 Kb
ADP5303. Data Sheet. SPECIFICATIONS. Table 1. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
ADP5303 Data Sheet SPECIFICATIONS Table 1 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
link to page 5
VIN = 3.6 V, VOUT = 2.5 V, TJ = −40°C to +125°C for minimum and maximum specifications, and TA = 25°C for typical specifications, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
INPUT SUPPLY VOLTAGE RANGE VIN 2.15 6.50 V SHUTDOWN CURRENT ISHUTDOWN 18 40 nA VEN = 0 V, −40°C ≤ TJ ≤ +85°C 18 130 nA VEN = 0 V, −40°C ≤ TJ ≤ +125°C QUIESCENT CURRENT Operating Quiescent Current in Hysteresis IQ_HYS 240 360 nA −40°C ≤ TJ ≤ +85°C Mode 240 520 nA −40°C ≤ TJ ≤ +125°C 640 1500 nA 100% duty cycle operation, VIN = 3.0 V, VOUT set to 3.3 V Operating Quiescent Current in PWM Mode IQ_PWM 425 630 µA UNDERVOLTAGE LOCKOUT UVLO UVLO Threshold Rising VUVLO_RISING 2.06 2.14 V Falling VUVLO_FALLING 1.90 2.00 V OSCILLATOR CIRCUIT Switching Frequency in PWM Mode fSW 1.7 2.0 2.3 MHz Feedback (FB) Threshold of Frequency Fold VOSC_FOLD 0.3 V SYNCHRONIZATION THRESHOLD1 SYNC Clock Range SYNCCLOCK 1.5 2.5 MHz SYNC High Level Threshold SYNCHIGH 1.2 V SYNC Low Level Threshold SYNCLOW 0.4 V SYNC Duty Cycle Range SYNCDUTY 100 1/fSW − ns 150 SYNC/MODE Leakage Current ISYNC_LEAKAGE 50 150 nA VSYNC/MODE = 3.6 V MODE TRANSITION Transition Delay from Hysteresis Mode to tHYS_TO_PWM 20 Clock SYNC/MODE goes logic high from PWM Mode cycles logic low EN PIN Input Voltage Threshold High VIH 1.2 V Low VIL 0.4 V Input Leakage Current IEN_LEAKAGE 25 nA FB PIN Output Options by VID Resistor VOUT_OPT 0.8 5.0 V 0.8 V to 5.0 V in various factory options PWM Mode Fixed VID Code Voltage Accuracy VFB_PWM_FIX −0.6 +0.6 % TJ = 25°C, output voltage setting via factory fuse −1.2 +1.2 % −40°C ≤ TJ ≤ +125°C Adjustable VID Code Voltage Accuracy VFB_PWM_ADJ −1.5 +1.5 % Output voltage setting via the VID resistor Hysteresis Mode Fixed VID Code Threshold Accuracy from VFB_HYS_FIX −0.75 +0.75 % TJ = 25°C Active Mode to Standby Mode −2.5 +2.5 % −40°C ≤ TJ ≤ +125°C Adjustable VID Code Threshold Accuracy VFB_HYS_ADJ −3 +3 % −40°C ≤ TJ ≤ +125°C from Active Mode to Standby Mode Rev. A | Page 4 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY DETAILED FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATIONAL MODES PWM Mode Hysteresis Mode Mode Selection OSCILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH PRECHARGED OUTPUT 100% DUTY CYCLE OPERATION ACTIVE DISCHARGE VINOK FUNCTION THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses PRINTED CIRCUIT BOARD LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
