Datasheet ADP5301 (Analog Devices) - 8
Description | 50 mA/500 mA, High Efficiency, Ultralow Power Step-Down Regulator |
Pages / Page | 21 / 8 — ADP5301. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. NCY. ICI. … |
Revision | C |
File Format / Size | PDF / 729 Kb |
ADP5301. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 100. NCY. ICI. VIN = 2.5V. VIN = 3.0V. VIN = 3.6V. VIN = 4.2V. VIN = 5.0V
ADP5301 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
VIN = 3.6 V, VOUT = 2.5 V, L = 2.2 µH, CIN = COUT = 10 μF, fSW = 2 MHz, TA = 25°C, unless otherwise noted.
100 100 90 90 80 80 %) %) ( ( 70 NCY NCY E E 70 ICI 60 ICI F F F F E VIN = 2.5V E 60 VIN = 2.5V 50 VIN = 3.0V VIN = 3.0V VIN = 3.6V VIN = 3.6V VIN = 4.2V 50 VIN = 4.2V 40 VIN = 5.0V VIN = 5.0V VIN = 6.0V VIN = 6.0V
004
30
007
40 0.001 0.010 0.100 1.000 10.000 0.001 0.010 0.100 1.000 10.000
13169-
LOAD CURRENT (mA)
13169-
LOAD CURRENT (mA)
Figure 4. Hysteresis Efficiency vs. Load Current, VOUT = 1.2 V Figure 7. Hysteresis Efficiency vs. Load Current, VOUT = 1.5 V
100 100 90 90 80 %) %) ( ( 80 NCY NCY E 70 E ICI ICI F F F F 70 E E 60 VIN = 2.5V VIN = 3.0V VIN = 3.0V VIN = 3.6V VIN = 3.6V 60 50 VIN = 4.2V VIN = 4.2V VIN = 5.0V VIN = 5.0V VIN = 6.0V VIN = 6.0V
005
40
008
50 0.001 0.010 0.100 1.000 10.000 0.001 0.010 0.100 1.000 10.000
13169-
LOAD CURRENT (mA)
13169-
LOAD CURRENT (mA)
Figure 5. Hysteresis Efficiency vs. Load Current, VOUT = 1.8 V Figure 8. Hysteresis Efficiency vs. Load Current, VOUT = 2.5 V
100 100 90 90 80 70 %) ( 80 (%) 60 Y C NCY N E 50 IE ICI F F 70 FFIC 40 E E VIN = 2.5V 30 VIN = 3.0V VIN = 3.6V V 60 IN = 3.6V V 20 IN = 4.2V VIN = 4.2V VIN = 5.0V 10 VIN = 5.0V VIN = 6.0V VIN = 6.0V
006
50 0
009
0.001 0.010 0.100 1.000 10.000 0 100 200 300 400 500
13169-
LOAD CURRENT (mA) LOAD CURRENT (mA)
13169- Figure 6. Hysteresis Efficiency vs. Load Current, VOUT = 3.3 V Figure 9. PWM Efficiency vs. Load Current, VOUT = 1.2 V Rev. B | Page 8 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATION MODES PWM Mode Hysteresis Mode Mode Selection OSCILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH A PRECHARGED OUTPUT 100% DUTY CYCLE OPERATION ACTIVE DISCHARGE VOUTOK FUNCTION THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses PRINTED CIRCUIT BOARD (PCB) LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
