Datasheet ADP5301 (Analog Devices) - 9
Description | 50 mA/500 mA, High Efficiency, Ultralow Power Step-Down Regulator |
Pages / Page | 21 / 9 — Data Sheet. ADP5301. 100. (%). FFIC. IN = 2.5V. IN = 3.0V. VIN = 3.0V. IN … |
Revision | C |
File Format / Size | PDF / 729 Kb |
Data Sheet. ADP5301. 100. (%). FFIC. IN = 2.5V. IN = 3.0V. VIN = 3.0V. IN = 3.6V. VIN = 4.2V. VIN = 5.0V. VIN = 6.0V. 200. 300. 400. 500
Data Sheet ADP5301 100 100 90 90 80 80 70 70 (%) 60 (%) 60 Y Y C C N 50 N 50 IE IE FFIC 40 FFIC 40 E V E V IN = 2.5V IN = 2.5V 30 V 30 IN = 3.0V VIN = 3.0V V V 20 IN = 3.6V 20 IN = 3.6V VIN = 4.2V VIN = 4.2V 10 VIN = 5.0V 10 VIN = 5.0V VIN = 6.0V VIN = 6.0V 0 0
010 013
0 100 200 300 400 500 0 100 200 300 400 500 LOAD CURRENT (mA)
13169-
LOAD CURRENT (mA)
13169- Figure 10. PWM Efficiency vs. Load Current, VOUT = 1.5 V Figure 13. PWM Efficiency vs. Load Current, VOUT = 1.8 V
100 100 90 90 80 80 70 70 (%) 60 (%) 60 Y Y C C N 50 N 50 IE IE FFIC 40 FFIC 40 E E 30 V 30 IN = 3.0V V VIN = 3.6V 20 IN = 3.6V 20 V V IN = 4.2V IN = 4.2V V 10 VIN = 5.0V 10 IN = 5.0V V V IN = 6.0V IN = 6.0V
1
0
1
0
0 014
13169-
LOAD CURRENT (mA)
13169- Figure 11. PWM Efficiency vs. Load Current, VOUT = 2.5 V Figure 14. PWM Efficiency vs. Load Current, VOUT = 3.3 V
160 350 140 –40ºC –40ºC +25ºC +25ºC +85ºC 300 +85ºC A) 120 A) n +125ºC n +125ºC ( ( NT 100 NT 250 80 CURRE N CURRE W NT 200 60 CE DO S E HUT UI S 40 Q 150 20 0 100
012 015
2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 2.3 2.9 3.5 4.1 4.7 5.3 5.9 6.5 V
13169-
IN (V) V
13169-
IN (V)
Figure 12. Shutdown Current vs. VIN, EN = Low Figure 15. Hysteresis Quiescent Current vs. VIN, SYNC/MODE = Low Rev. B | Page 9 of 21 Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION BUCK REGULATOR OPERATION MODES PWM Mode Hysteresis Mode Mode Selection OSCILLATOR AND SYNCHRONIZATION ADJUSTABLE AND FIXED OUTPUT VOLTAGES UNDERVOLTAGE LOCKOUT (UVLO) ENABLE/DISABLE CURRENT LIMIT SHORT-CIRCUIT PROTECTION SOFT START STARTUP WITH A PRECHARGED OUTPUT 100% DUTY CYCLE OPERATION ACTIVE DISCHARGE VOUTOK FUNCTION THERMAL SHUTDOWN APPLICATIONS INFORMATION EXTERNAL COMPONENT SELECTION SELECTING THE INDUCTOR OUTPUT CAPACITOR INPUT CAPACITOR EFFICIENCY Power Switch Conduction Losses Inductor Losses Driver Losses Transition Losses PRINTED CIRCUIT BOARD (PCB) LAYOUT RECOMMENDATIONS TYPICAL APPLICATION CIRCUITS FACTORY PROGRAMMABLE OPTIONS OUTLINE DIMENSIONS ORDERING GUIDE
