ADP2442Data SheetParameter SymbolTestConditions/CommentsMinTypMaxUnit POWER GOOD PGOOD High, FB Rising Threshold5 89 92 95 % PGOOD Low, FB Rising Threshold5 111 115 118 % PGOOD High, FB Falling Threshold5 106 109 112 % PGOOD Low, FB Falling Threshold5 83 86 89 % PGOOD Delay tPGOOD 50 μs High Leakage Current IPGOOD(SRC) VPGOOD = VCC 1 10 μA Pull-Down Resistor IPGOOD(SNK) FB = 0 V 0.5 0.7 kΩ SYNC/MODE SYNC/MODE Input Logic High 2 V Logic Low 0.8 V Pulse Width 100 ns 1 Guaranteed by design. 2 Measured between VIN and SW pins and includes bond wires and pin resistance. 3 Based on bench characterization. Measured with VIN = 12 V, VOUT = 1.2 V, load = 1 A, fSW = 1 MHz, and the output in regulation. Measurement does not include dead time. 4 Based on bench characterization. Measured with VIN = 15 V, VOUT = 12 V, load = 1 A, fSW = 600 kHz, and the output in regulation. Measurement does not include dead time. 5 This threshold is expressed as a percentage of the nominal output voltage. Rev. B | Page 4 of 36 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION TYPICAL CIRCUIT CONFIGURATION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EFFICIENCY IN FORCED FIXED FREQUENCY MODE EFFICIENCY IN PULSE SKIP MODE INTERNAL BLOCK DIAGRAM THEORY OF OPERATION CONTROL ARCHITECURE Fixed Frequency Mode Pulse Skip Mode ADJUSTABLE FREQUENCY POWER GOOD MODE OF OPERATION EXTERNAL SYNCHRONIZATION SOFT START UNDERVOLTAGE LOCKOUT PRECISION ENABLE/SHUTDOWN CURRENT-LIMIT AND SHORT-CIRCUIT PROTECTION THERMAL SHUTDOWN APPLICATIONS INFORMATION ADIsimPOWER DESIGN TOOL SELECTING THE OUTPUT VOLTAGE SETTING THE SWITCHING FREQUENCY EXTERNAL COMPONENT SELECTION Input Capacitor Selection Inductor Selection Output Capacitor Selection BOOST CAPACITOR VCC CAPACITOR LOOP COMPENSATION LARGE SIGNAL ANALYSIS OF THE LOOP COMPENSATION DESIGN EXAMPLE CONFIGURATION AND COMPONENTS SELECTION Resistor Divider Switching Frequency Inductor Selection Input Capacitor Selection Output Capacitor Selection Compensation Selection SYSTEM CONFIGURATION TYPICAL APPLICATION CIRCUITS DESIGN EXAMPLE OTHER TYPICAL CIRCUIT CONFIGURATIONS POWER DISSIPATION AND THERMAL CONSIDERATIONS POWER DISSIPATION Inductor Losses Power Switch Conduction Losses Switching Losses Transition Losses THERMAL CONSIDERATIONS EVALUATION BOARD THERMAL PERFORMANCE CIRCUIT BOARD LAYOUT RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
